| Latest | 0 Rplys |
01-29-2014, 12:05 AM | #46 | ||
Re: PLEASE HELP!! Jeep stalling?
06-22-2014, 04:03 PM | #47 | |
I have a 96 jeep grand cherokee loredo that started sputtering n backfiring n would not respond to throttle half the time. It got so bad that it was either pedal to the floor or nnothing. Went on for a week n then checked the connnection to the fuel pump. It was worn out n had a lil ccorrosion on it so i closed the female holes and connected it back together. Havent had a problem since.
06-21-2016, 04:22 AM | #48 | |
Re: PLEASE HELP!! Jeep stalling? I have a solution to the GC Dying/Stalling issue!
I've been down the above path for years, and out of the blue, 'Randy' a guy on Craigslist stopped by and got me thinking.
On this GC there is the ccv in the back of the valve cover, which then runs to the intake manifold for vacuum. The intake runs over to the.... wait for it..... PURGE SOLENOID! . If it is bad, like mine was, it will stop the vacuum to the intake, send codes to the PCM, and you engine will die, stall, and periodically get hard to start. You can read all about this nasty critical part on the web, so I'll not go there. RESULTS! I replaced this 40$ part, and my jeep ran like a champ. That's it in a nut shell. I'm posting this solution in as many groups as I can find, that I have reviewed in the several years working this problem. Please pass this on to others, and if you want, provide my contact info as credit. Just trying to contribute to this HUGE problem our GC's are having. Try it, and let me know. Sincerely, The reaper(now). |
11-14-2016, 02:58 AM | #49 | |
My Jeep lives... no thanks to Chrysler engineers. I have had an issue with my Jeep randomly stalling for about 3 years. I researched the internet, Jeep clubs, and spoke with several mechanics. Needless to say everyone had a different solution.
It ended up being the wire going from the Alternator to the battery and fuse box. Something none of the experts even considered. Those of you who know about wiring... Chrysler engineers used 8-AWG wiring from the alternator and 6-AWG for the starter and the negative/ground. I discovered an issue with the wiring after I had played the role of a typical mechanic; testing and swapping out all of the usual culprits. I connected my 1/0-AWG jumper cables between my Jeep and my car. When connected, the Jeep ran OK, it stalled every know and then, but would start back up after a few seconds. If I disconnected the cables, the Jeep would die with in 5 minutes... every time. So, I tested the alternator. It was operating perfectly. Then why was my battery going dead? And, why was my Jeep dying? I removed the flexible plastic cover from the wires coming off the battery and the alternator to discover; (a) they were unusually small in diameter, and (b) they had several burn marks along the wire run. I have enough of a background with electronics to know that the skinny little wires were overheating and causing a drain on my electrical system. Think of running a compressor with a cheap extension cord... you get the picture. I replaced the cables to the starter, alternator, and fuse box with 2-AWG, 300 amp, 680 strand welding cable. I also added replaced the two 6-AWG negative battery cables with 2-AWG. I then added four 2-AWG grounding cables, grounding the engine to the frame and body in different locations. Overkill... YES. "Binford 5000" Everything runs better now. The Jeep started up without any hesitation. It idles better. It accelerates better. It no-longer randomly stalls. Total cost including a hydraulic crimper... $90. |
