Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 07-04-2004, 11:03 PM   #1
kenr
'89 325i loses power after warming up
Hi All,
A recurring problem. Replaced fuel pump 2 years ago, and I believe the relay as well.
The car does just fine at cold start. The car loses power after some period of time, when warmed up. Then check engine light comes on. At this point it will idle roughly, but not quite stall. It will NOT accelerate, but chugs and sputters badly when given more throttle. Then, it will suddenly run fine and strong again.
Presently, just tried it, no warning lights and running smoothly after cooling for several hours.
Any suggestions?
Thank you!
Ken
kenr is offline   Reply With Quote
Old 07-05-2004, 08:57 AM   #2
ulrichnielsen
got same problem!!
Hi, just entered this forum and saw your problem..I have the same problem - did you find a solution??
Thanks
ulrichnielsen is offline   Reply With Quote
Old 07-05-2004, 11:05 AM   #3
kenr
Re: '89 325i loses power after warming up
Not yet.
Same year/model?
Old 07-05-2004, 11:14 AM   #4
jeffreyb4me
sounds like a sticking [closed] fuel pressure regulator. review earlier posts on proceedure and see what Engine Code[s] are stored..................jb.
jeffreyb4me is offline   Reply With Quote
Old 07-05-2004, 11:17 AM   #5
kenr
Thanks jb. Will do.
Ken
Old 07-05-2004, 04:11 PM   #6
kenr
OK, I bought and installed a new FPR. We'll see if that fixes it.
Pic:
http://www.4activeaudio.com/images/FPR.jpg
How to, referencing an '87. Mine was even easier:
http://member.rivernet.com.au/btaylo...placE30M3.html
Hope this helps,
Ken
Old 07-05-2004, 07:04 PM   #7
jeffreyb4me
okay, hope I don't need to start standing closer to my patented 'DIAGNOSTIC DARTBOARD' or tweak it too much, I was hoping to begin marketing it soon &
the decision weighs on your results..................jb.
Old 07-06-2004, 01:41 AM   #8
ulrichnielsen
thanks, will try what your suggestion. Mine is a E30 320i 1983. Will keep you informed of any results..
Old 07-06-2004, 05:31 PM   #9
kenr
jb, I'm cool with the dartboard diagnostic. Just tell me you weren't blindfolded!
Good luck, Ulrich.
Ken
Old 07-06-2004, 08:13 PM   #10
jeffreyb4me
no, no, no....I, ahh, actually in your case, I threw it over my shoulder facing away from the board looking in a mirror, but that was after some practice.......................................... ..........jb.
Old 07-27-2004, 11:39 AM   #11
kenr
It's been a couple of weeks now, and the problem of losing power has changed, but hasn't been fixed.
The problem shows up on "cold" start now. Cold in quotes because it's summertime in CA, after all.
Any other ideas?
Thank you, there has to be plenty of room left on the dart board!
Ken
Old 07-27-2004, 11:45 AM   #12
bimmerman333
bimmerman333's Avatar
Wink
your problem could be a bad oxygen sensor, or the throttle position hace them diagnosed good luck i had the same prob it was the o2 sensor . 93 325 i
bimmerman333 is offline   Reply With Quote
Old 07-27-2004, 11:52 AM   #13
kenr
A new O2 sensor was part of some repairs I had done to fix this problem a couple of years ago. Could it have failed already?
Throttle position, like a dead spot? Linkage?
Ken
Old 07-27-2004, 11:56 AM   #14
bimmerman333
Talking
it could if your car burns a little oil it could clog the o2 sensor triggering rough idle. try running premium gas with some fuel cleaner i like red line fuel treatment. and take it on the highway and open it up a . make sure you run the gas u have in it now completly out before treatment
Old 07-27-2004, 11:59 AM   #15
bimmerman333
throtle position should messed with only by a knowledgable mechanic. it controls the air to gas mixure which affects idleof the car.
