Go Back   Automotive Forums .com Car Chat > BMW > 5 Series
Old 11-05-2009, 08:00 PM   #1
junbeltran
540 1997 steering wheel shakes
hi .every time i run 50 miles per hour i feel shaking on my steering wheel..i did balance on my tire and alignment..still the same..can you help me...
junbeltran is offline   Reply With Quote
Old 11-15-2009, 06:57 AM   #2
camelpipe
Re: 540 1997 steering wheel shakes
I had same problem found it to be the rear wheels out of balance
Hope this helps
camelpipe is offline   Reply With Quote
Old 11-21-2009, 04:52 PM   #3
danielsatur
1) Have your tires check, and speed balanced.
danielsatur is offline   Reply With Quote
Old 11-27-2009, 06:15 PM   #4
bmwmech1
bmwmech1's Avatar
These cars and earlier 5 and 7 series cars, use a tension or thrust arm in the front suspension geometry, which has a large rubber busing on the end that mounts to the chassis. When this bushing wears, the suspension is able to move forward and aft more than is normal and any slight out of round or out of balance wheel will magnify the movement into the classic 50-65mph shimmy. Have the bushings checked, replaced if needs be and a good balancing of your wheels and all will be good...
Garey
bmwmech1 is offline   Reply With Quote
Old 11-28-2009, 03:28 PM   #5
arks
Yup- sound like thrust arm bushings to me.
Don't tighten them too much when installing or they'll bind.
1970 Chevrolet C10 stepside w/IROC motor
2001 BMW 530i:
5 speed, Sport, Premium, Cold, Dinan Stage 2, General G-Max tires
2008 Ford F250 XLT 2WD
2017 Mazda CX-5 Grand Touring AWD
arks is offline   Reply With Quote
Old 12-02-2009, 11:08 PM   #6
jfkenigma
These 540's and 740's series have two lower ball joints the one that goes from the spindle to the back (the other goes to the middle of the car) will cause this problem now once you done installing it do not tight the bushing part until the weight of the car is completely resting on the ground that is to prevent bushing from twisting and fail prematurely
jfkenigma is offline   Reply With Quote
Old 02-05-2012, 04:40 AM   #7
safwan051432
safwan051432's Avatar
tyres , and car suspension system is the root cause of this type of vibration
safwan051432 is offline   Reply With Quote
