Old 06-18-2017, 09:47 PM   #1
lezdep
How to dis-assemble Minichamps McLaren F1 1/12 model
Need help.
I have started (sort of) my own conversion project to convert Minichamps die-cast into a static model
of LeMans 1995 winning car. And second step is to dis-assemble die-cast model. I've removed all
bottom screws. I've found 6 so far, 4 bigger and 2 smalls ones. However chassis and body don't want
to come apart still. Front is coming out, but it looks like something is holding the rear part. If anyone
knows, please explain me how to take it apart ? I suspect I'm missing something.
It looks like there could be 2 more screws at the top of rear wheel arcs. They are hard to see and impossible
to reach without removing rear wheels. Is there a way to remove rear wheels on this die-cast ?
Thanks a lot in advance for help.
lezdep is offline   Reply With Quote
Old 07-03-2017, 03:50 PM   #2
lezdep
Re: How to dis-assemble Minichamps F1 1/12 model ?
I've got help from F1 dedicated forum. Apparently there were 2 more screws at the top of rear wheel arches.
Following an advice from F1 forum, I've removed rear tires from the wheels and that opened access to those hidden screws.
After that block was removed I was able to dis-assemble the rest of it with pretty much no issues.
It turned out to be a decent model with high level and accuracy of detail for a die-cast. There will be a lot of things that would
have to be improved and converted to specs of racing car. But it provides a decent starting platform, imho. This is my "dream"
project. Hopefully I will be able to make a reasonable conversion into F1-GTR from LeMans 1995 over next number of years.
Here are some photos of the process.
