Go Back   Automotive Forums .com Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Thread Tools Search this Thread
Old 09-25-2001, 07:40 PM   #1
ragt20
ragt20's Avatar
Send a message via AIM to ragt20
Question how to change springs?
Is there a post here on how to change springs on the P11....I should be gettin my H&Rs soon, any help on how to change them would be wellcomed........the only post I could find was one sayin that the rear are easy, and would be better to do two at a time.....
ragt20 is offline   Reply With Quote
Old 09-26-2001, 12:23 PM   #2
kenchan
kenchan's Avatar
yep, the best thing to do is to go to the tein site.
tein.co.jp and download their pdf instructions on the HP11 for TYPE NA.
goood instructions on there with pictures and everything. only thing is, it's in japanese, but the illustrations speak for themselves.
when you raise your front up make sure you put another jack under the front arm so that the arm doesn't go down so far that the drive shaft joint doesn't come apart. dat would suck trying to put it back together. hehehe.
goodluck.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
kenchan is offline   Reply With Quote
Old 09-26-2001, 06:48 PM   #3
ragt20
ragt20's Avatar
got the springs today......can't wait to get them on......tried getting the pdf from the tein site......but all I get is errors and blank screens when trying to view the pdf on my PC......
have also bought the Haynes Manuel, but in there they show U to remove the complete unit of the car b4 changing the spring...I thought there wasn't a need for this.........:help:
Old 09-26-2001, 08:01 PM   #4
P11GT
P11GT's Avatar
Send a message via AIM to P11GT Send a message via Yahoo to P11GT
yours is the same as mine, i believe. You do need to remove the whole strut.
Firstly, with the front struts, remove wheel, undo strut brace bolts, undo strut retaining bolts, undo the top and bottom strut bolt which is on the top and bottom of the black coweling, and the whole strut comes off. Get your spring compressors and wind the spring down. You then need a good pair of pliers or mole grips to hold the centre shaft, and you'll need a deep ring spanner to undo the bolt. Once youve remobed the bolt, carefully remove the cover plate and bushes making sure you know which way they go back on. Then remove the spring. Repeat process to refit.
The rear strut is a bit easier. Remove wheel, look up inside the wheel arch and you'll see a collar around the strut top with two bolts. Remove the bolts at the top, and the bolt at the bottom, and presto! it'll come straight out. Do the same as the front to change the spring and then refit.
Simple.
Best to jack up the whole front or rear end and do both sides at the sametime.
I'll dig up some photos and post them. If still in doubt, email me.
Kevin
File Type: jpg unbolt top and bottom bolt on cover to remove shocker.jpg (97.4 KB, 165 views)
UK's 1st Turbo'd Primera GT
Please visit my site www.p11-gt.co.uk Updated 7/3/2003
Some Exterior Mods to go now.
Vote for my car at www.ridejudge.com user name P11GT
VRRRROOOOOOMMM TIIISSSSSSHHHTT!!!
P11GT is offline   Reply With Quote
Old 09-26-2001, 08:04 PM   #5
P11GT
P11GT's Avatar
heres another
Old 09-26-2001, 08:21 PM   #6
ragt20
ragt20's Avatar
cheers M8.....though still slightly ....e-mail me more info/pics if U can....thanks.......I'd like to get it lowered b4 the Goodwood meet.....
Old 09-26-2001, 08:32 PM   #7
P11GT
P11GT's Avatar
ragt- check your mail
Old 09-26-2001, 08:41 PM   #8
ragt20
ragt20's Avatar
done
Old 09-26-2001, 08:44 PM   #9
P11GT
P11GT's Avatar
youve bloody confused me alright!!
you need MSN Messenger to chat. Download and install it.
Old 10-22-2001, 11:10 PM   #10
GtRider
Send a message via AIM to GtRider
Question
does anybody know if you have to compress Intrax lowering springs for p10?
GtRider is offline   Reply With Quote
Old 10-23-2001, 12:04 AM   #11
G22DET
G22DET's Avatar
Send a message via ICQ to G22DET Send a message via AIM to G22DET
you always gotta compress the springs when you lower cars...in order for it not to shoot out and poke your eyes out i am serious though.
normally, you would take out the entire strut, compress the springs, open the top strut hat, take the springs out from the shocks and put new, lowering springs over the struts...compress the lowering springs so you can put the top hat back on, put the entire strut back in the car and done.
Luke C.
GDA Power!
G22DET is offline   Reply With Quote
Old 10-23-2001, 02:23 PM   #12
GtRider
Question
does anybody know how to change springs on the P10?
Old 10-23-2001, 05:12 PM   #13
G-Forces
Banned
G-Forces's Avatar
Pretty much same way. A strut's a strut basically.
G-Forces is offline   Reply With Quote
Old 10-23-2001, 11:46 PM   #14
GtRider
so changing the springs on the p10 is basically the same way to change on a p11?
Old 10-23-2001, 11:47 PM   #15
G420
Send a message via AIM to G420
what do you guys think???
Hey guys I got a quote the other day for H&R springs installed for $315. Do you guys think thats a decent price????:smoka:
2002 White G20 sport
18" Alessio Vueltas
Pirelli 225/40/18
G420 is offline   Reply With Quote
Bookmarks
Search this Thread:
