Old 02-20-2015, 10:06 AM   #16
mrceej
Re: ’73 Camaro
Looking great all around. I have a question for you, I've noticed a lot of casting of pieces (with others too). Do you just keep a stash of parts specifically for copying? And do you have just molds of previous work tucked away?
mrceej is offline   Reply With Quote
Old 02-20-2015, 10:19 AM   #17
Scale-Master
Scale-Master's Avatar
Re: ’73 Camaro
Not really. I make masters or modify existing parts to fit what I need. The 4 speed trans for example went back into the near virgin kit so it can be built. I try to make copies first then modify my casting so the kit parts remain intact.
While I do keep the molds I usually don't run them unless I need that part, or sometimes I'll stock up on things like wheels when I'm casting and want to use up the leftover extra mixed resin.
Scale-Master is offline   Reply With Quote
Old 02-20-2015, 10:27 AM   #18
Scale-Master
Re: ’73 Camaro
Originally Posted by Hemi Killer View Post
The infamous 4L60E, I'm on my 4th.
Yeah, I've broken the 700R4 a few times too. Now it has extra clutches, the shifter has a 4th gear lockout for the track and I set the TV cable to shift at a lower RPM on the street. Been working fine for at least 18 years.
The Following User Says Thank You to Scale-Master For This Useful Post:
Hemi Killer (03-21-2015)
Old 02-20-2015, 10:31 AM   #19
das_auto
das_auto's Avatar
Re: ’73 Camaro
It's got to be great to make a model of a car that you actually own IRL. Very easy to get good reference. Keep up the nice and also very clean work!
Emil
Men love women...but even more than that! Men!...Love!...CARS!
das_auto is offline   Reply With Quote
Old 03-16-2015, 10:40 AM   #20
Scale-Master
Re: ’73 Camaro
I made the headers from a pair out of a Revell SuperTruck kit. I cut some of the tubes apart and made the flanges from brass. I cut off the long collectors and made new ones to match mine from brass and then added P.E. flanges.
Old 03-17-2015, 12:05 PM   #21
Scale-Master
Re: ’73 Camaro
This is the kit supplied ’70 console. ’73 Camaros used a different style.
I filled in, built up and reshaped the kit part.
Then I cut out the opening for the shifter plate in the correct location, added the console door and textured it.
Old 03-17-2015, 02:23 PM   #22
hirg
Re: ’73 Camaro
i take my chair!!
hirg is offline   Reply With Quote
Old 03-19-2015, 10:35 AM   #23
Scale-Master
Re: ’73 Camaro
I made a copy of the graphic equalizer. To give some depth to the shifter plate area I put the gear selector lettering and the blue plastic dust cover in the recess of the console. I made the shifter plate to sit flush above with some space between like the real car.
Old 03-19-2015, 10:38 AM   #24
kans0002
kans0002's Avatar
Re: ’73 Camaro
Really great work! I follow all you builds and am always very impressed!
Any chance you can show us some pics of the 1:1 car?
kans0002 is offline   Reply With Quote
Old 03-19-2015, 02:06 PM   #25
Scale-Master
Re: ’73 Camaro
tonioseven (04-22-2015)
Old 03-19-2015, 03:33 PM   #26
hirg
Re: ’73 Camaro
Nice work on seats!!
Old 03-19-2015, 03:42 PM   #27
kans0002
kans0002's Avatar
Re: ’73 Camaro
1:1 looks great too!
Old 03-20-2015, 06:17 PM   #28
Scale-Master
Re: ’73 Camaro
Thanks guys. The 1:1 is a blast to drive.
I made a Hurst T-handle shifter to match the real one. Yes, it is an automatic, but I custom made the shifter in the car to work with the 700R4. This piece can be filed away until final assembly.
Old 03-20-2015, 10:06 PM   #29
hirg
Re: ’73 Camaro
Awesome good!
Old 03-21-2015, 10:47 AM   #30
Scale-Master
Re: ’73 Camaro
Thanks!
I decided to use the kit provided engine with some modifications. First I cut the 4 speed manual transmission off and cemented the engine halves together.
After painting it I made a decal for the Fram filter.
