Go Back   Automotive Forums .com Car Chat > GMC > Jimmy
Old 08-28-2006, 07:47 PM   #1
CanukGMC
SQUEEK SQUEEK SQUEEK argh!
Ok I can't figure this out. My engine squeeked when I first bought it, I changed the belt and it went away. Not 5 months later the belt began sqeeking again, and got progressively louder. I applied some belt dressing and it went away. 2 days later it came back. I applied more dressing until the dressing was basically only working for 10 mins at a time. FINE I changed the belt out in the driveway, I always thought you'd get more than 5 months out of a belt but ok sure whatever. So here I am 5 days after putting a new belt in again and the squeeking is BACK! I can belt dressing the squeek away but it comes back after about a day of driving.
I pulled the tensioner pulley and the idler (the useless one at the top of the engine between the AC and the alternator) and they both looked ok, I squirted some silicone lube into the bearings on them (as best I can since they are a sealed unit). I re-attched them and bang the squeek remains. Belt dressing makes it go away again so I don't think its the pulleys.
Wtf is going on? Anyone know what would eat belts in such short order?
Things I noted:
-The tensioner seems to jump up and down frequently while the engine idles, almost like the belt is changing load on it or something, so it's popping up and down alot. Are they supposed to? Bad tensioner? Or is maybe the AC pump (even thought it's NOT turned on, it clicks on and off) loading and unloading the belt?
-The weird attached-to-nothing pulley (I've always called them idler pulleys) looks fine and rolls fine but I noted when I spun the bearing\bolt assembly and held the pulley in my hand the bold appeared to be off center slightly, almost like it was maybe bent a degree or two? Could this be hurting anything? The pulley does have a very very faint wobble to it while running but it doesn't appear to be pulling on the belt.
Anyone?
CanukGMC is offline   Reply With Quote
Old 08-29-2006, 02:50 PM   #2
horse482
AF -Advisor
horse482's Avatar
Re: SQUEEK SQUEEK SQUEEK argh!
Using belt dressing on a micro-v belt is not a good idea it will plug the cogs on the belt and the pulleys. The build up from the dressing will cause a squeek. To fix your problem you will need to get a new belt and clean all of the pulleys with a wire brush to make sure that you get all of the shit off that you put on there.
P.S. Belt Dressing was designed for V-Belts as a temp fix.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
horse482 is offline   Reply With Quote
Old 08-29-2006, 07:21 PM   #3
CanukGMC
Well it did make the squeeks go away, and the squeek did return on it's own without the assistance of belt dressing. I changed the tensioner out just now and ran the engine. No squeeks yet however I do hear a strange sound like marbles rolling around in there, by listening along the front of the engine it is exactly as loud along the entire front of the engine, so who knows what that's coming from. Maybe it has to do with the squeek.
Old 08-29-2006, 07:30 PM   #4
maxwedge
A990 racer
Take the belt off and turn all the pulleys by hand see if you feel a roughness in any of the pulley bearings.
maxwedge is offline   Reply With Quote
Old 08-29-2006, 07:32 PM   #5
CanukGMC
Did that and found none, at least none apparent by hand. I wonder if my AC is going, I noted it cycles on and off every 5 seconds or so, even when turned off.
Old 08-30-2006, 08:57 AM   #6
jeffharley
Send a message via AIM to jeffharley
I had that problem, I changed the idler pulley and it went away. BTW it did not seem as though the pulley was bad just turning it by hand but under a load it made the bearing squeal
jeffharley is offline   Reply With Quote
Old 08-31-2006, 10:27 PM   #7
Rick Norwood
Big Tall Dumb Ass
Rick Norwood's Avatar
I have the same problem on my 2000 Jimmy SLE. I have replaced the belt approx. 3 times and it needs it again. I replaced the Tensioner and Idler it didn't help. I would love to find out why so I could stop buying $30 belts.
A new belt usually buys me about year of peace and quiet.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Rick Norwood is offline   Reply With Quote
Old 09-01-2006, 09:27 AM   #8
CanukGMC
I wish I got a year, it comes back in days now...
It's started a new kind of squeek too, which is the other thing I hate about this problem, it's constantly changing. Now it'll squeek nonstop while driving, up and down the RPM scale UNLESS I completely redline the engine, at exactly 5500rpm the squeeking\grinding stops and won't come back for another day or so. Wtf?
Old 09-01-2006, 09:11 PM   #9
CanukGMC
Well I've narrowed it done to 1 of a million things...
When the engine starts up cold the squeek is there, reving it up to redline does NOTHING to change it other than speed it up with the engine. If I put it in gear and drive I can run the engine up to red, whether by flooring it, or by limiting it to 1st gear, and the squeek disapears at EXACTLY the rev limiter (wtf?!). After doing this the squeek is TOTALLY gone until next time it starts cold.
Anyone?
Old 10-11-2006, 11:57 PM   #10
Slayer0420
Slayer0420's Avatar
I would be a lil more concerned with the "marbles" sound than a squeek .
My friends Toyota started sounding like marbles and it turned out to be the water pump.
2000 Chevy Venture
Slayer0420 is offline   Reply With Quote
Old 07-06-2014, 09:50 AM   #11
Piejoe50
You might check your crankshaft pulley. The ones with rubber in them tend to shift and become a little out of position thus putting a different angle on the belt making it sqeak
Piejoe50 is offline   Reply With Quote
Old 07-06-2014, 10:22 AM   #12
aleekat
I realize you are new here. Your answer may help someone but not this guy. Post is 8yrs old.
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
