Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-12-2017, 08:38 PM   #1
merrillwebb
1997 dodge ram 2500 5.9 diesel
both of my lights, the brake light and the abs light, came on at the same time. the brakes work fine. what may have caused the lights to come on?
thanks.
merrillwebb is offline   Reply With Quote
Old 09-13-2017, 06:58 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: 1997 dodge ram 2500 5.9 diesel
A faulty brake light switch....do your brake lights work?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 02-22-2018, 08:34 PM   #3
imakedacookies
I have a 2000 cummins and had both lights come on too. Turns out my hydro boost was leaking the power steering fluid. Lost enough fluid before I realized and my rear brakes stopped working. Check your power steering resivoir. Once I filled it my brakes were fine but the lights stayed on. Probably a computer thing. May or may not be your issue. Just figured I'd let you know what my issue was and how I fixed it. Hope it helps
imakedacookies is offline   Reply With Quote
The Following User Says Thank You to imakedacookies For This Useful Post:
Chris Stewart (02-23-2018)
