Go Back   Automotive Forums .com Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 11-05-2004, 09:38 PM   #91
Xtreme_098
Xtreme_098's Avatar
Send a message via MSN to Xtreme_098
Re: afte burners
Camber kits? Skunk2 sells themf or Integras, RSX's, Civics, and del sols for 300 dollars. Don't know if thats a lot though. Haven't looked at others.
Xtreme_098 is offline   Reply With Quote
Old 11-06-2004, 02:12 AM   #92
240sxAddict
240sxAddict's Avatar
Send a message via AIM to 240sxAddict Send a message via Yahoo to 240sxAddict
Re: afte burners
wow i wish that was my car D-BO but as u have learned that is not my car. the one on my sig is my baby
I Like Girls And When I See Them I Get Big Bone In My Pants!
240sxAddict is offline   Reply With Quote
Old 11-07-2004, 11:59 PM   #93
RedFC3S
RedFC3S's Avatar
Re: afte burners
Originally Posted by Suislide
Red's car is the sex.
one will be parked in my driveway very shortly, if everything goes to plan...but i'm probably going to go ported NA at first and turbo it later maybe.
thanks man
actually, read up on the rotary motor a little more, you cant turbo an N/A 13B, you need to just start out with a 13B-T
1990 RX-7 Turbo II, Streetport, 62-1 Ball Bearing Turbo, FMIC, R.E. Amemiya exhaust, Haltech E6K, GReddy gauges, Apex-i AVC-R, and much much more
Under a complete Time Attack/Drift makeover
RedFC3S is offline   Reply With Quote
Old 11-08-2004, 12:02 AM   #94
RedFC3S
RedFC3S's Avatar
Re: afte burners
as long as you dont get a 240, you will be ok
Old 11-08-2004, 08:20 PM   #95
Partizan
Partizan's Avatar
Re: Re: afte burners
He said in the midst of the 240 forum...
Partizan is offline   Reply With Quote
Old 11-08-2004, 09:54 PM   #96
nissanfanatic
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: afte burners
Hmmmm. Running rich. Can anyone say either burning up exhaust valves or damaging your turbo? Either the unburnt fuel explodes somewhere after the combustion chamber(backfires) and can potentially cause turbocharger damage or it burns continously and can raise turbine inlet temps(EGT) to 2000F. This will definately shorten your turbochargers life. I'm pretty sure your exhaust valves won't be too happy either. This is why care must be taken when selecting cams for a turbocharged engine to avoid too high of a valve overlap. If these fires aren't occuring under tuned conditions with properly selected cams, fix them. The only reason a fire should occur is because the throttle blade closes while the remaining air in the intake tract between the MAFS and throttle blade has been metered. This air is not entering the combustion chamber fast enough so the computer is dumping all this fuel into the engine. Its kinda like what someone said earlier with the fuel lag. I knew it was a bad idea to open this thread.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
nissanfanatic is offline   Reply With Quote
