Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 12-09-2013, 11:53 AM   #1
hotpipes
Fuel smell & bad gas milage
My 2002 6 cylinder Malibu gives an odder of gas when turning on the heater it has had a fuel pump and filter install 8 months ago and there has not been any smell until I used the heater this winter. I understand fuel consumption is more when using the heater but this is ridiculous I go around 8 or 10 miles and i've used more than a quarter of a tank.
hotpipes
hotpipes is offline   Reply With Quote
Old 12-09-2013, 12:07 PM   #2
aleekat
Re: Fuel smell & bad gas milage
Your heater has nothing to do with fuel other than the smell mixing some fresh air with heat. I would look at fuel pressure regulator bad or leaking. Also around the injectors. Unless you are leaking fuel at pump or filter.
Post back, that's what makes Forums Work.
aleekat is online now   Reply With Quote
Old 09-30-2016, 03:37 PM   #3
hotpipes
Thanks aleekat
I replaced the fuel pressure regulator and no more fuel smell. It was a job that I would not like to do very many times I needed to remove many parts to be able to replace the regulator. I would hate to think what a repair shop would charge for that job.
The slow response was because I had checked the part several times and it didn't show a leak.
hotpipes
