Go Back   Automotive Forums .com Car Chat > Ford > F Series
Old 03-10-2017, 11:09 AM   #1
SGrueber
2008 F350 P0529, P0488 and P10104
So i changed out my throttle body because I was getting a P0488 code. I took it for a drive after and it was doing its regen and came up with the drive to clean filter, then it came up with cleaning filter and then proceeded to give a check engine light and wrench with the codes above including the same code again I had to replace the throttle body.
FYI the throttle body when I took it out would not reset back to its position so it definitely needed to be changed.
P0529 seems to be pointing at the Fan Clutch now..
Any ideas now?
SGrueber is offline   Reply With Quote
Old 03-11-2017, 10:54 AM   #2
65comet
65comet's Avatar
Re: 2008 F350 P0529, P0488 and P10104
Brian did a pretty good YouTube video on the 0488 problem. Here is the link
https://www.youtube.com/watch?v=h8e6obp2S88
65comet is offline   Reply With Quote
Old 03-11-2017, 02:22 PM   #3
SGrueber
I used this video to change my throttle body. The additional codes happened afterwards. I think I have them solved now though and one was potentially a loose connection on the throttle body, it didn't click in so could of wiggled loose. the other thing I did was disconnect the batteries for 10 mins and ran the truck for 15 mins afterwards and the combination of those 2 things made all my codes and check engine light disappear.. so it was one of those 2 things...
