Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Old 12-01-2020, 08:06 PM   #1
jeffmorris1956
Different kinds of camshafts required for different kinds of lifters?
Are different kinds of camshafts required for different kinds of lifters? For example, camshafts for solid lifters with or without rollers, and camshafts for hydraulic lifters with or without rollers. I have been watching "Engine Power" TV show.
jeffmorris1956 is offline   Reply With Quote
Old 12-02-2020, 07:08 AM   #2
maxwedge
A990 racer
Re: Different kinds of camshafts required for different kinds of lifters?
Yes roller cams are different then cams for flat tappet lifters, also hydraulic vs flat tappet.
maxwedge is online now   Reply With Quote
Old 12-02-2020, 06:02 PM   #3
jeffmorris1956
The men in the TV show talked about lift, duration, and lobe separation. Lobe separation is usually about 110 degrees. They talked about degreeing the camshaft so that the valves don't hit the pistons. They just built an engine that generated 1200 HP!
