| Latest | 0 Rplys |
02-12-2008, 05:37 PM | #106 | |
Re: Ferrari 360 Modena, fully open
I agree....Color match the rim spokes to the body color, with a chrome or aluminum lip.
great job so far! |
02-12-2008, 06:20 PM | #107 | ||
02-12-2008, 08:38 PM | #108 | |
I used model master metalizer plate aluminum on some mustang cobra wheels, and quite honestly I think they turned out better than the real deal.
There is a very fine line between "hobby" and "mental illness." |
02-13-2008, 02:12 AM | #109 | |
Thanks for the great suggestions for the wheels, I like them all! Actually I've already gone ahead with an idea I had for the wheels, I hope you will like them (later).
I finished some work that I was really looking forward to. Tamiya's engine bay includes some well molded areas where the engine hood gas springs mount. Seeing that, I could not possibly finish this model without making my own gas springs. So here are the hood and springs in detail... I installed very fine brass bushings. The rod runs all the way through to keep things aligned. Here is the piston arm of the gas spring. It really has to be one piece for strength, hence the bend. But this makes it more difficult to install the boss, which I also wanted to do in one piece... But look mom, it might squeeze around the corner Yes! That saves messing around with shaping, aligning, and attaching some super small pieces. So far so good. The sleeve end. The solder fills the inside to make the corner solid. Test fitting. It's a goer - just need to clean up the ends. Those are small brass tubes soldered to the inside of the hood. The bottom end complete. Top end. Final check. It works nicely - a miniscule kink in the rod creates enough friction to hold the weight of the hood. Finishing off the mess where the PE is attached to the plastic. Should have used polyester here, but Mr Dissolved Putty is nice to work with. You have to wait a few days for it to fully stabilize. Still a few loose ends to tidy up before it's finished, but getting close now! |
02-13-2008, 03:19 AM | #110 | |
I'll have to search for my jaw first, than I'll try to find the right words to describe your work!
02-13-2008, 08:50 AM | #111 | |
Simply amazing, did you have any problem soldiering brass to PE parts or PE is brass also, can't really see from the picture.
02-13-2008, 09:35 AM | #112 | |
Insane! Incredible work
Come clean - this might be your second plastic model but it's hard to believe that you are new to this kind of small scale, detail work What's the story? PS If this IS all new to you, change your screen name to Micheal Angelo - because you a genius!
Guideline for happy modeling: Practice on scrap. Always try something new. Less is more. "I have a plan so cunning, you could put a tail on it and call it a weasel" - Edmund Blackadder |
02-13-2008, 01:32 PM | #113 | |
This is exactly why I love this forum... just sensational!!!
02-13-2008, 01:40 PM | #114 | |||
It seems to me that modeling is a pretty simple equation of care and detail vs time - you can do as incredible and detailed a job as you want, but it will cost you in time. I actually want to do a whole string of easy OOB builds just to become more efficient, in fact this build was supposed to be one of those. I take my hat off to the master modelers on this site - the work and artistry is just unbelievable, much of it far beyond me at this stage. Everyone here seems to share a pursuit of perfection, I think we must have been exposed to some nasty chemicals or disease as kids |
02-13-2008, 01:54 PM | #115 | |
Lovely work on the engine cover 'struts' (is that the right word ?) They look so real....
Steve Noble |
02-13-2008, 03:17 PM | #116 | |
Holy crap man, those hinges are wonderful.
02-13-2008, 05:27 PM | #117 | ||
02-13-2008, 06:31 PM | #118 | ||
02-13-2008, 09:11 PM | #119 | ||
What's next? I'd love to see what you can do with a Revell kit. Maybe the 599, Superamerica or 430? |
02-14-2008, 01:17 AM | #120 | ||
