Old 06-22-2006, 07:47 PM   #1
thecackster
thecackster's Avatar
Send a message via MSN to thecackster
Exclamation Question: Regular gas in Diesel vehicle
I know this is the wrong forum...but i need an answer TONIGHT....a friend put about a quater of a tank of regular fuel in a deisel truck....should we siphon it out or will it be okay....I know he's a dumbass.
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
thecackster is offline   Reply With Quote
Old 06-22-2006, 07:52 PM   #2
ThatRoundHeadedKid
ThatRoundHeadedKid's Avatar
Re: Question
I think it will most likely not run so you may have to siphon it.
Ride #1: 1994 Mercedes-Benz W124 E320 Coupe (My first car/love)
Ride #2: 1975 Mercedes-Benz W116 280S (The restoration/hobby/project car)
~Chris~
My Diecast Collection!
ThatRoundHeadedKid is offline   Reply With Quote
Old 06-22-2006, 07:54 PM   #3
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
Re: Question
Good question....I know that diesel in a gas engine will do very bad things but don't know for sure about gas in a diesel.
Diesels work by compression and gasoline doesn't blow up from compression alone. I'd think (aka guess) that the gas wouldn't burn at all and would make the diesel run rough.
Best to drain it, and the dumbass.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
fredjacksonsan is offline   Reply With Quote
Old 06-22-2006, 07:56 PM   #4
thecackster
Re: Question
haha yea..i told him to get it siphoned...and wouldn't it be just on top being lighter?????? or the whole tank???? Thanks alot
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 06-22-2006, 07:58 PM   #5
fredjacksonsan
Re: Question
good point.....I'd do a little test to be sure, like some diesel and gas in a jar or something, but excellent idea, should be able to siphon off the top and not have to waste the whole tank. Give it some time to settle though.
Old 06-22-2006, 08:16 PM   #6
Toksin
Non-profit Organisation
Toksin's Avatar
Send a message via AIM to Toksin
Re: Question
Drain it, otherwise it's going to fuck up the seals on the fuel pump, then you'll have a much bigger problem on your hands.
Toksin is offline   Reply With Quote
Old 06-22-2006, 08:26 PM   #7
-The Stig-
On Fire!
-The Stig-'s Avatar
Send a message via AIM to -The Stig-
Re: Question
I say, as long as you haven't tried to run it with the gas in the tank, if you syphon out the contents (all of them) you should be okay.
Just add fresh fuel (diesel!) to the tank and let her go. Just don't run the motor with no fuel, cause if get air into the line, you'll have to bleed the injectors and that can be a pain in the ass.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
-The Stig- is offline   Reply With Quote
Old 06-24-2006, 08:09 AM   #8
TexasF355F1
TexasF355F1's Avatar
Send a message via AIM to TexasF355F1
Re: Question: Regular gas in Diesel vehicle
If he ran it, everythings going to have to be drained. My friend put diesel in her civic once and it had to be towed.
How did this happen?
*Under Construction - New sig to debut*
TexasF355F1 is offline   Reply With Quote
Old 06-26-2006, 05:36 PM   #9
MonsterBengt
Lol, I saw a video of a diesel car on the highway filled with gas. Not a pretty sight, never seen so much smoke before.
MonsterBengt is offline   Reply With Quote
Old 06-27-2006, 12:54 AM   #10
thecackster
it was really only 8 gallons in however big a tank so not too bad i guess....
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 07-01-2006, 12:14 PM   #11
beef_bourito
beef_bourito's Avatar
Re: Question
actually gasoline does detonate on compression, that's how you get knocking. if the air gets hot enough it'll ignite the gasoline.
since gasoline is more combustible than diesel (by that i mean it'll burn more quickly and easily) it might not burn but explode and cause damage to the internals. also it could mess up a bunch of stuff in your fuel system.
have the tank drained and fill it up with diesel.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
beef_bourito is offline   Reply With Quote
Old 07-28-2006, 10:56 PM   #12
erb
Actually you can run some gas in a diesel engine.
Alice in Chains
Rest in peace Layne.
erb is offline   Reply With Quote
Old 07-28-2006, 11:36 PM   #13
Moppie
Master Connector
Moppie's Avatar
Not more than about 10% though, and even though running that level for a long period can be bad for the fuel pump/line/injector seals etc. Especialy if its a modern unleader gasoline, which often contains lots of corrosive solvents.
You also need to be aware that the petrol will clean out any carbon depositis in the combustion chamber, good thing on a newer engine, bad on an old one. Iv seen an old high millage diesel engine that was only holding compression because of the carbon build up. Someone half filled it with petrol, and drove it half way accross the city, where all the carbon deposits broke up and the engine lost all compresion.
Moppie is offline   Reply With Quote
Old 10-28-2006, 06:29 PM   #14
1337cshacker
Im no expert here. If the gas is mixed with the diesel, when the diesel combust it might combust the regular gasoline. Like someone else said it will run hot and not sound to good. If it happened once I dont think damage should be a problem. Definatly drain the bitch, and slap the fool.
cars:
1990 black 300D merc-benz Tdiesel @ 261k miles. 2.5L
-Sold audi A8
1337cshacker is offline   Reply With Quote
Old 06-16-2007, 11:58 PM   #15
ss_chevy
diesel fuel injection components (ie injection pump, injectors) have very tight clearances off the top of my head i think .001-.003 of an inch diesel fuel has lubricating properties that prevent metal to metal contact of these component's internal workings which would cause them to seize gasoline depletes the lubricating properties of diesel fuel (its more like an oil gasoline a solvent)
ss_chevy is offline   Reply With Quote
