Old 04-08-2001, 05:21 PM   #1
enzo@af
Old Mod
enzo@af's Avatar
Send a message via ICQ to enzo@af Send a message via AIM to enzo@af
I just bought some Intrax springs, and I was wondering if a friend and I should try and install them ourselves, or should I just pay the dough and have them professionally installed.
So, does anyone here have experience doing this? I can get them compressed for pretty cheap, it would just be a matter of swapping them for the stock springs. However, I worry about correct camber, and everything else that could go wrong.
If anybody has any suggestions on the matter, please either reply or give me an e-mail or get ahold of me on ICQ!!!!
Thanks, and later.
I've said it before, I'll say it again. "Nobody does rip and snort like Ferrari"
enzo@af is offline   Reply With Quote
Old 04-09-2001, 07:03 AM   #2
CraigFL
CraigFL's Avatar
Are these coil over shocks, McPherson struts or coil on axles??
They are each varying degrees of difficulty but not that bad to do.
CraigFL is offline   Reply With Quote
Old 04-09-2001, 10:30 AM   #3
enzo@af
Old Mod
enzo@af's Avatar
I'm pretty sure it's Mcpherson. I haven't ever heard, but just from looking at it that's the impression I get. Plus, it's a small, FWD car.
Old 04-09-2001, 04:30 PM   #4
CraigFL
CraigFL's Avatar
These are medium difficulty. You need to compress the springs to take off one of the ends so it can be removed. Usually the spring is fairly large outside diameter and a large pitch so that it's difficult using the screw type spring compressors with the hooks. They tend to slip on the spring as they are tightened. Your easiest way may be to take the struts off the car and take them to someone who can compress and remove the springs safely. They can install the new ones easily so all you have to do it bolt them back on again.
Old 04-09-2001, 08:36 PM   #5
TheMan5952
Volvo Guy
Send a message via AIM to TheMan5952
Becareful if you tackle it yourself.
So your dropping your Paseo huh? Or just replacing the stock ones?
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
TheMan5952 is offline   Reply With Quote
Old 04-09-2001, 08:37 PM   #6
texan
Writer Mod
texan's Avatar
what car is this on?
'03 Corvette Z06
'99 Prelude SH
texan is offline   Reply With Quote
XJ Rear Leaf Spring Swap Problems Jim Aldrich Cherokee 1 04-04-2010 08:25 PM
Detachable Spring under front seat adamchrissy Type 1 1 03-14-2009 09:58 PM
how to change Springs dilema 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 09-09-2004 05:03 AM
Changing Springs - How? Giffer2 Prelude 1 08-29-2003 04:11 AM
how to change springs? ragt20 Suspension 29 10-26-2001 03:54 AM
