Go Back   Automotive Forums .com Car Chat > Toyota > Avalon/Pronard
Old 07-02-2014, 04:14 PM   #1
Ducaire
1999 Avolon only getting 18-20 mpg
I'm having a hard time finding out why this 99 model Avalon gets such poor gas mileage, and most of the driving is done on the road (55-60 mph).
-I've checked the air filter and it's clean.
-The tires have plenty of air (35 psi).
-I don't hotrod the car (no going from 0 to 60 in 5 seconds).
-I'm pretty sure I'm measuring the gas mileage correctly; I fill up, keep track on how many miles I put on it in between fill-ups, and then divide the number of miles by the number of gallons it takes to fill it up (example: I drive 190 miles and fill up again, and it takes 10 gallons to fill it up, 190 divided by 10 is 19, so it'd be 19 mpg).
-The engine runs fine; it does not run hot and has plenty of power other than the fact the gas mileage is so low.
-The transmission shifts fine (engine probably never gets over 2,500 rpm as I accelerate).
Now I do live on a dirtroad, and the car has 218k miles on it, so this could be a factor as well. But any ideas on why the gas mileage is so poor?
Ducaire is offline   Reply With Quote
Old 07-03-2014, 12:32 AM   #2
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Re: 1999 Avolon only getting 18-20 mpg
Don't judge the mileage by one fill-up. Total and average 4 or 5 fill-ups. What about on highway trips where you are only driving 55-60 mph for extended periods on flat terrain with the a/c off and the windows closed? This is where you get your best mileage and the best judge of what your car is capable of.
Are you filling the tank with the recommended octane gas as stated in the owner's manual? Lower octane gas can decrease your ignition advance to prevent knocking and lower your gas mileage. I believe your recommended octane is 91 or better for best engine performance.
Spark plugs?
Fuel injectors need cleaning?
How's the mileage with the a/c off as described above?
Don't idle for long periods.
Check parking brake adjustment.
Changed transmission fluid?
Alignment?
Check your intake duct for cracks and loose connections.
PCV valve
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
The Following User Says Thank You to Brian R. For This Useful Post:
Boosted S13 (02-28-2017)
Old 07-15-2014, 07:35 AM   #3
bcopeland
I agree with all of the above. Check your air filter and do you have custom tires on the car (not the original size that the car calls for)? Sure its not missing or a coil on plug is out?
bcopeland is offline   Reply With Quote
Old 02-28-2017, 08:20 AM   #4
Boosted S13
Exclamation Re: 1999 Avolon only getting 18-20 mpg
I have a 2003 Avalon and had the same problem. One way to tell is if the idle is high. Our car had 140k miles and started idling high (14-1800 rpm) and getting only 20-21 mpg. We changed the spark plugs; it is possible that one cylinder wasn't firing. It helped a lot.
Boosted S13 is offline   Reply With Quote
