Go Back   Automotive Forums .com Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-24-2005, 07:48 PM   #31
94tegRS
94tegRS's Avatar
Re: b16a/b vs b18b/c vs h22/23 vs b20 FAQ
I actually read in a honda tuning once that stock B series injectors are up to the task up to somewhere just over 200WHP I think it was, I know it was morre than 200 but less then 250, I dont think I have that mag anymore though, but thats a big step up from stock numbers. not sure what size injectors are in the acords V6, but the B series are 240cc's I believe.
what kit are you thinking of getting for your accord?
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
94tegRS is offline   Reply With Quote
Old 03-30-2005, 11:29 PM   #32
98preludeh22a
obd2 connect plug
I have a 98 prelude with a h22a in it. I had five guys look at my car . 2 of them were mechanics . I ask them were do i plug in the scanner .they said the obd2 insert plug located under the dash . Look there not one to be found. Looked in passenger kick panel, behind clove box, under ash tray , under the hood on the fire evry where. I cant fine it now were. If you now were it is located please email me. Thanks P.s non sh
98preludeh22a is offline   Reply With Quote
Old 04-13-2005, 04:52 PM   #33
xixtony
Send a message via AIM to xixtony Send a message via Yahoo to xixtony
does any one knoe wht the s2000 engine is called???
xixtony is offline   Reply With Quote
Old 04-13-2005, 05:22 PM   #34
Greenblurr93
Kind of a Big Deal
Greenblurr93's Avatar
Send a message via MSN to Greenblurr93
F20C1, found in less than a minute searching on this site....
Greenblurr93 is offline   Reply With Quote
Old 04-13-2005, 07:40 PM   #35
SiGNAL748
SiGNAL748's Avatar
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
also keep in mind that the new S2000's now come with an F22C.
SiGNAL748 is offline   Reply With Quote
Old 04-13-2005, 08:43 PM   #36
Greenblurr93
Kind of a Big Deal
ahh yes...
Old 04-14-2005, 06:36 AM   #37
civicson234
b16 (jdm civic sir-2)bolts up to an automatic? please help im waiting on my car to arrive and i want to have everything i need ready to go!
http://www.ratemybody.com/profile.aspx?userID=198056
civicson234 is offline   Reply With Quote
Old 04-14-2005, 04:23 PM   #38
SiGNAL748
SiGNAL748's Avatar
Assuming you have B-Series auto tranny (example: B18 Integra Auto Trannies will work) to go with it, yes, it will bolt up.
Old 04-26-2005, 04:20 PM   #39
AMV8(1day)
Re: Re: b16a/b vs b18b/c vs h22/23 vs b20 FAQ
Originally Posted by gotstreet
I have a 1991 Honda Accord, ive got a h22 VTec, headers, full exaust, intake I got the computer chipped and a Vtec Controller.
About a month ago I got I tuned and got the VTec controller adjusted and thrown on the dyno came up to 231hp ..
im now having problems with it and i was wandering if anyone could hepl me figure out what was wrong with it..
It lost allot of power, It used to red line at 8.5 now it red lines at 6 .
when im sittin at idle the rpms are up and down between 1.5 and 800 also when i am comming to a stop the rpms stick at 1.7 until i come to a complete stop then up and down... the exsuast sounds different than it was(almost silent)
CAN SOMEONE HELP
Sounds like an IAC motor gone bad, happens all the time.
but I can't garantee thats the prob.
could be a tranny prob.
you could just replace the IAC motor from a junker and go from there or you could take it back to the people that tuned it and complain that they screwed somthin up and they'll probably give you a discount on whatever it needs.
AMV8(1day) is offline   Reply With Quote
Old 04-26-2005, 08:10 PM   #40
94tegRS
94tegRS's Avatar
Re: Re: Re: b16a/b vs b18b/c vs h22/23 vs b20 FAQ
IACV wouldnt have anything to do with redline, or at least it shouldnt. dont see how it could put the ecu into limp mode just because it wont be able to keep a steady idle. also everytime ive driven in the safe mode redline was like 3 grand. not saying its the same on all but thats my experience
current
history:
Old 06-18-2005, 05:14 PM   #41
boyertownMidnight3
Send a message via AIM to boyertownMidnight3 Send a message via Yahoo to boyertownMidnight3
ok i gotta 1988 honda civic DX hatchback (im new to honda's) but i gotta few questions...
1. is my engine a 1.5 or a 1.6.... and if its a 1.5 how much horse power does it got stock.....
2. also whats the biggest engine i could put in my car with out having to do some major mod's???
3. if my car is a 16 valve SOHC is there any V-tech cylinder heads that will fit my car?
4. also i know HP means horse power but what does PS mean??
okay im sorry for the really stupid questions but im just trying to learn..
thanks,,,,,
boyertownMidnight3 is offline   Reply With Quote
Old 06-18-2005, 06:44 PM   #42
94tegRS
94tegRS's Avatar
1. look at your engine, its gonna say D15 or D16, thats how you tell, but an 88 DX, that has a 92HP 1.5L
2. easiest would be the DOHC ZC so then it would only be ECU and engine you have to deal with, and a little bit of wiring for the MPFI over the DPFI you have stock. next step would be a B series. Id probably go with 90-91 teg B18 just for ease of wiring, not as powerful as the newer ones but would be much better than that puny 1.5.
3. the Z6 and Y8 SOHC VTEC heads will bolt onto your block with some machining, and some wiring. but for the price, a ZC would be cheaper and if the ZC you got was truly a low mileage, good condition engine it'd be quicker than the mini-me swap would be.
4. I knew this at one time but forgot exactly what it stands for, its just a measurment of energy they use in other countries, like NM for torque instead of ft/lbs. I think that ones something like newton/meters or something but not sure, and PS I dont have a clue.
current
history:
Old 06-19-2005, 02:23 AM   #43
1990_cRx
hi, im thinking on doing a swap into my crx but i was wondering if the H22 (190hp) will fit. i've heard and seen this on websites that this is possible, i asked two of my friends about this one of them said that it was imposible and the other said it could be possible but its costly and also h22 are heavy which makes it difficult when turning. im knew on this so need a lot of help...thanks....
1990_cRx is offline   Reply With Quote
Old 06-19-2005, 05:02 AM   #44
94tegRS
94tegRS's Avatar
I dont know the exact weight differences, but the B series is I think 50-60 pounds heavier than the D series, and then the H is another 60-70 on top of that, so you will have 110-130 lbs additional weight in the front, so the front will drop a bit, and youll probably need to get adjustable dampening shocks and turn them a bit harder than stock to deal with the extra weight. and it does upset the already front weight bias, but it shouldnt be so bad, then again ive never driven a H equipped civic. also Id look into some brake upgrades sicne the brakes are used to stopping a car with 130 pounds less weight and a lot less power. if you drive normally they ll handle it but when you hoss they will not work after so long. my HB's brakes already fade like none other just from how fast I get going from a stock B18.
and yes its possible, www.hasport.com
current
history:
Old 09-12-2005, 08:50 PM   #45
civic ops
civic vs tiburon
Is there any way that my stock civic with a d16y8 beat a 97 tiburon that apears to be stock
civic ops is offline   Reply With Quote
