Old 07-30-2015, 06:03 AM   #1
Johan_SWE
Application of Liquid Decal Film
What is the best way of applying Microscale Liquid Decal Film to custom, ink printer printed, decals?
Has anyone tried spraying it using an airbrush?
I tried once before to apply it the way stated on the bottle, with a brush, and that smeared the ink out
That time in the end I used some advice from another post and just sprayed some Tamiya clear coat TS-13 over them.
Worked, but I think the decals were a bit too thick after this treatment and did not follow the contours of the parts perfectly.
/Johan
Johan_SWE is offline   Reply With Quote
Old 07-30-2015, 04:07 PM   #2
MidMazar
MidMazar's Avatar
Re: Application of Liquid Decal Film
i have never used it, but im sure others will shine in. I would spray them with a few mist coats first, then one or two heavier coats. I would also spray on scrap decals to see what happens.
In Progress
Old 07-30-2015, 10:29 PM   #3
GTRfan01
i have only used a brush, i have never had ink run but it is hard to not get streaks in the film (does not dry flat).
i cannot see why you could not use an air brush, this is how i was planning to use this product in the future.
if in doubt maybe email microscale?
GTRfan01 is offline   Reply With Quote
Old 07-31-2015, 04:22 AM   #4
Kjenjak
Kjenjak's Avatar
I have only applied it by brush so far. With a big brush, to cover much area in one stroke. If you do it carefully, you can disribute it in a nice even way. You shouldn't use more than 2 immidiate strokes with the brush, more will smear the ink.
If you want the decal to shine, you should apply it onto the painted surface (after the treatment with LDF, and cover everything with gloss clear.
<img src=http://www.automotiveforums.com/vbulletin/image.php?u=698755&type=sigpic&dateline=1361304198 border=0 alt= />
Kjenjak is offline   Reply With Quote
The Following User Says Thank You to Kjenjak For This Useful Post:
Johan_SWE (07-31-2015)
Old 07-31-2015, 07:28 AM   #5
Johan_SWE
Just noticed off topic where you live.
I worked in Forchheim, just down the A73, ten years ago.
Introduced all visiting friends and family to beautiful Bamberg !
Old 08-04-2015, 07:37 AM   #6
Vric
Vric's Avatar
Tick coat with a brush.
Every time I tried with an airbrush, the result cracked in the water, no matter how many coat I did.
Vric is offline   Reply With Quote
Old 08-04-2015, 10:30 AM   #7
Rasputen
I use a big, soft brush that I keep only for this task. The bristles are probably 5 cm long.
Rasputen is offline   Reply With Quote
Old 08-25-2015, 09:51 AM   #8
Kjenjak
Kjenjak's Avatar
A good choice!
You probably also liked the Schlenkerla beer.
I can't return the favour directly, I'm afraid, as I've never been to Stockholm so far, but I'm in Göteborg ~2 times per year, to pay my regards to Volvo.
Old 08-26-2015, 06:05 AM   #9
lovegt40
ItaloSvensk
lovegt40's Avatar
world is little....and I love when I see min kompis here (even if I am in imported one...)
JOhan my way to work with custom made decals is this:
Ater printing I apply ts-13 as protective (or any other syntetic not water soluble glossy medium, but before make test to see if they are not too aggressive. The one sold in citygross is perfect btw..).
when all is dry, better after 2/3 days u can threat with everything to softenr it. BMF film is quite hard so I use gunze decal film,instead of microscale.
Make some test of course before use it seriously on a model.
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
lovegt40 is offline   Reply With Quote
