Go Back   Automotive Forums .com Car Chat > Toyota > 4Runner/GX470
Old 11-12-2019, 07:48 PM   #1
CharlieCh
Engine surges when driving
Hello,
I have a 2016 4runner SR5 v6. It has 17k miles on it. Recently I found that when I drive at a constant speed the rpm surges from 1500 up to 3000 for no reason and then goes back to normal after several seconds. I noticed this last saturday, usually when I drive at 40-50 mph.
Any opinion on this is appreciated!
Thank you!
CharlieCh is offline   Reply With Quote
Old 11-14-2019, 06:45 PM   #2
fourwd1
AF -Advisor
fourwd1's Avatar
Re: Engine surges when driving
I'd start by checking to see if any OBD-II error codes have been set.
Even if the CEL light isn't on a code may have been set that may help diagnose your problem.
- - as seen in FOUR WHEELER magazine July 06 and OFF-ROAD magazine Feb 07 - -
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
fourwd1 is offline   Reply With Quote
Old 01-29-2020, 12:54 AM   #3
ramnick
Try to clean the MAF sensor also.
ramnick is offline   Reply With Quote
Old 02-18-2020, 09:34 PM   #4
j cAT
Originally Posted by CharlieCh View Post
Hello,
Thank you!
NOT A COMMON PROBLEM THAT YOU HAVE...
I have the same runner you have 2016 SR5..
I on forums every day TOYOTA 4RUNNERS ,, this can be a improper transmission fluid issue could be a leak causing this. bring to dealership it is under warranty.
1500 RPM @40 MPH is normal ... 3000 RPM drivetrain ...
Bookmarks
Search this Thread:
