Go Back   Automotive Forums .com Car Chat > Ford > Escort
Old 12-16-2016, 07:31 PM   #1
nate_c
drivebelt removal (tensioner broken)
I have a 1995 escort 1.9L engine. I'm trying to replace the power steering pump. In order to do so, i have to remove the drivebelt. My issue is, the tensioner has been broke off. So I can't loosen it. Is there another way to remove the drive belt with out it?
nate_c is offline   Reply With Quote
Old 01-20-2017, 08:00 PM   #2
denisond3
Re: drivebelt removal (tensioner broken)
Even if you could slide the serpentine belt off one of the pulleys, you would need to be able to rotate the tensioner in order to get the belt back on. You can buy the tensioners, probably for $40 or so. You can unscrew the tensioner using the bolt with the 13mm head. You will likely have to raise the engine an inch or two in order to get the bolt out. You do this by supporting the oil pan with a jack (and block of wood between jack and oil pan), then unbolting the motor mount on that side of the engine.
And to change the water pump, you would need to remove the timing belt cover, which will involve taking off the motor mount "isolator", as well as the crankshaft pulley.
If course, you may have already done all of this. Sorry I didnt see this sooner.
denisond3 is offline   Reply With Quote
Tags
1995 , escort , ford
