Go Back   Automotive Forums .com Car Chat > Buick > Park Avenue
Old 07-12-2018, 06:10 AM   #1
buick8791
Buick Park Avenue headlight problem
Hi,
an other problem( no crank problem solved) related to head lights, which has been long time.
I replaced the non functioning dimmer switch located in steering column, but still I havenīt hi beams. Low beams are ok.
I get 12v from dimmer switch wires measured from the big connector under the dash for low and hi beams, the fuses are ok under dash fuse box as well as under hood fuse center.
I canīt get 12 v to green wire for hi beam near to lamp.
Could you please help me to check the wiring and relays etc. related to hi beam.
I have not an good and accurate wiring diagram to check the things.
BR,
Pentti
buick8791 is offline   Reply With Quote
Old 07-12-2018, 08:49 AM   #2
maxwedge
A990 racer
Re: Buick Park Avenue headlight problem
Get a wiring diagram on autozone.com, register, go to repair guides.
Bookmarks
Search this Thread:
