Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 04-22-2014, 12:08 PM   #1
tempfixit
Head gasket repair additives,
I have a 98 Windstar with 243K and I believe I have a bad head gasket or cracked head. 3.0 Vulcan engine. The tail pipe is clean telling me that I am burning coolant and the level does go down very, very slowly.
Question is what head gasket additives does everyone recommend, thermagasket, steel seal, etc.
I do not have the time currently to do the repair correctly.
thanks
Larry
tempfixit is offline   Reply With Quote
Old 04-22-2014, 02:10 PM   #2
12Ounce
Re: Head gasket repair additives,
I'm sorry, but I think "Elbow Grease" is the only effective additive...chemical or otherwise.
12Ounce is offline   Reply With Quote
Old 04-23-2014, 07:45 AM   #3
phil-l
Well - it isn't the "right" fix, but I've had some good experiences with Bar's Leaks. I once used it to delay dealing with a friend's outrageously-difficult-to-get-to heater core. The infamous coolant smell disappeared from the car, and no more moisture on the windshield. That was several years ago; last I heard, it's still working...
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
phil-l is offline   Reply With Quote
Old 04-23-2014, 11:32 AM   #4
tempfixit
I did smell antifreeze about a month ago but have not lately.
I have used bars leak before but I do not like that it plugs heater cores. I am thinking of getting some sodium silicate and trying that. I need to do some testing to make sure I am getting gases in the coolant and which cylinder it is.
I know replacing gaskets and checking heads and surfaces is the best fix but right now it is not a good time for me to do the repair.
Any other opinions greatly appreciated.
Old 04-23-2014, 12:15 PM   #5
phil-l
Note that Bar's Leaks has several products - at least one of which contains sodium silicate. One may be a good match for your situation. I looked here for info:
http://barsproducts.com/catalog/bran...ponent/cooling
1995 Contour GL 2.5
Old 04-23-2014, 12:35 PM   #6
jerryg2112
Years ago I fixed a head gasket leak on a 88 regal with alumaseal or a similar aluminum flake product. The leak was by the firewall and it was sealed for years. Don't remember if there was oil in the coolant. It's like putting in pepper. You could try a pinch or two instead of the whole tube and then there would be less chance of clogging something else up.
jerryg2112 is offline   Reply With Quote
Old 04-24-2014, 03:31 PM   #7
tempfixit
Thanks for the link phil-l, I will probably try one. I was going to get some testing stripes but they wanted over $30 for a kit. I will probably use the heavy duty one of bars leak.
I keep you posted on results.
