Go Back   Automotive Forums .com Car Chat > Mitsubishi > 3000GT/Stealth
Old 01-17-2015, 05:00 PM   #1
Firebird1
Send a message via AIM to Firebird1
Crank Pulley removal
Do anybody out there know which direction the to turn the crank pulley bolt to loosen the Bolt? I'm trying to change the crank positioning sensor and the cam positioning sensor. I have changed the knock sensor. But just can't remove or break the crankshaft pulley bolt. Help!!!!!!
Firebird1 is offline   Reply With Quote
Old 01-20-2015, 08:07 PM   #2
Stealthee
Your worst nightmare
Stealthee's Avatar
Re: Crank Pulley removal
Righty tighty, lefty loosey, just like any other normal bolt.
Stealthee is offline   Reply With Quote
Old 01-22-2015, 03:44 PM   #3
toddrs93
toddrs93's Avatar
probably going to take air tools to get it off
toddrs93 is offline   Reply With Quote
Old 01-22-2015, 04:42 PM   #4
Stealthee
Stealthee's Avatar
I've done it without air tools many times. I even did it with no one holding the brake. I used a large screwdriver, or a pry bar, and slid it into the rotor vane and let it jam against the brake caliper bracket before applying muscle to break it loose.
Also I used a few extensions to get the breaker bar out past the fender to be able to apply the most amount of force.
Old 05-01-2015, 04:33 PM   #5
Firebird1
Thank you guys for the advise. I'll try those methods.
