| Latest | 0 Rplys |
03-27-2015, 04:33 PM | #1 | |
99 grand am se 2.4L will not go forward
I have a 99 Pontiac grand am se 2.4L that will not engage in drive. drained the transmission fluid, replaced the transmission pan, filter & gasket & put in new fluid. Will go in reverse but no drive. when in drive, 1st, 2nd or 3rd it will not go forward. Please help
03-29-2015, 09:55 PM | #2 | |
Re: 99 grand am se 2.4L will not go forward
Did you notice any metal in the pan? Was fluid burnt? Was level ok?
Have you checked for transmission codes? |
03-30-2015, 01:26 AM | #3 | |
Another Grand Am bites the dust. Unless there's a problem with your shifter cable, your transmission is done for. This happens a lot in Grand Ams, they weren't exactly built to last.
03-30-2015, 10:31 AM | #4 | |
Mike I have to disagree with you.......the 4T40/45E did not have a lot of problems....
04-06-2015, 06:49 PM | #5 | |
out saving the world
Welcome to AF jomcgruer69 !
How many miles on this GA ?? Did you check and make sure the shift cable is working ? If thats all good sounds like it'll need a trip to a trans shop. But its likely a shift solenoid is out, which is prob about time being a 99 GA. You can replace them yourself but its complicated. the whole drivers side axle and stuff needs removed to access them. no fun w/o the right tools. edit also these are decent transmission. the problems ive seen is the #1 clutches are way to small compared to the previous trans they used, 4T60/65E(65HD). They cant handle much HP either, once you get close to 300HP , you start burning up the clutches or breaking trans mounts...or the casing. which luckily Ive not done yet.
1999 Grand Am SS 3.4 OHV |
