Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 06-22-2016, 05:58 AM   #1
RedHawk46637
Left Caliper doesn't release!
I have a 1996 Chrysler-Town & Country Mini Van, 3.8 ltr, ABS, Automatic, A/C.
After applying the brakes, when I release them the left front brake caliper does not release properly. I can pop the bleeder valve open and the caliper releases. I have put 3 ea new/rebuilt calipers on it, replaced the pads, replaced the rotor e times also. No brake lines are kinked, I have power bled them and fluid flows easy out of bleeder.
(I had the same problem with a GMC once and it was the brake block that caused the problem)
I am wondering if this could be the problem also on this vehicle?
RedHawk46637 is offline   Reply With Quote
Old 06-25-2016, 06:58 PM   #2
RIP
AF -Advisor
RIP's Avatar
Re: Left Caliper doesn't release!
I would suspect the flex line has formed what amounts to an internal check valve from a loose piece of lining inside the line. Fluid will flow towards the caliper but not the other way.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
RIP is offline   Reply With Quote
Old 06-25-2016, 08:31 PM   #3
RedHawk46637
I will replace that flex hose and post the results. Thanks
Old 08-06-2016, 01:42 PM   #4
gromittoo
I assume that fixed it? IMHO, you should replace both of them. They are not hard to replace, if you are doing a brake job anyway.
My 98 Dodge Neon had the passenger side one lock up randomly, and it the extra work caused random overheating, and eventually took out the tranny. Only then did I find the problem.
I didn't learn, cause 5 years later, the Driver's side went.
gromittoo is offline   Reply With Quote
