Go Back   Automotive Forums .com Car Chat > Ford > Taurus | Taurus Wagon
Old 09-15-2013, 11:48 PM   #16
shorod
SHO No Mo
shorod's Avatar
Re: 2006 Taurus hard starting. Fuel pump?
The fuel pressure specifications are:
30-55 psi Key On Engine Off
26-45 psi Key On Engine Running.
Your pressure readings are within specifications so I wouldn't be quick to condemn the fuel pump or the pressure regulator.
Have you checked the air filter recently? Does the car start better if you manually hold the throttle open slightly when cranking the engine?
-Rod
shorod is offline   Reply With Quote
Old 09-17-2013, 01:48 PM   #17
E10ff
Rod, the air filter looks good and holding the throttle didn't help it start easier.
E10ff is offline   Reply With Quote
Old 09-17-2013, 09:12 PM   #18
shorod
SHO No Mo
shorod's Avatar
It's probably not starved for air then. The next thing I'll suggest you try is crank the engine to start it a few revolutions, but stop before the engine actually starts. Then pull a couple of spark plugs and inspect them for raw fuel to see if maybe too much fuel is entering the cylinders.
-Rod
Old 03-26-2017, 12:09 PM   #19
ronhud99
ronhud99 here so did u ever solve this problem as i have an 06 that does start when cold then shut down for half an hour then cranks for ten seconds with foot on gas pedal then stars up also runs fine after start
ronhud99 is offline   Reply With Quote
Old 03-26-2017, 12:19 PM   #20
E10ff
After I sold the car, the new owner texted me to tell me they found a bad injector. They changed it and it started like a champ after that.
Old 04-19-2017, 10:11 AM   #21
ronhud99
hi i have a 06 3.0 ohv and it is doing all of the things above starts up cold fine once warm it needs gas psdal half way down to start after 6 to 8 seconds stinks of gas when it starts also if u do short trips and start it after 10 mins or so it starts ok after 20 mins it seems like flooding out i hope u guys get to bottom of this soon i'm reading ur updates this is driving me crazy good luck ron
