Go Back   Automotive Forums .com Car Chat > Isuzu > Axiom
Old 05-05-2006, 06:20 PM   #1
cstepp
Unhappy Isuzu Axiom Ignition Key removal problem
My 2002 Isuzu Axiom sporadically will not allow the key to come out of the ignition while turning it off. It will turn partially, then stop and will not turn any further. It takes several times of moving the shifter back and forth and turning the key. I took it to a local dealer, he kept it for 6 weeks, said it was the shifter lock just needed tightening. When I went to pick it up, he said he did the best he could that I need to make sure it is definitely in Park and it should come out. If not, play with it back and forth. He said he worked on it about 2 hrs and charged me $110.00. I drove it home, put it in park and guess what, the key wouldn't come out - AGAIN! I move the shifter back and forth numerous times and turned the key numerous times and finally, it came out. It is the same thing. Any advice?
cstepp is offline   Reply With Quote
Old 05-06-2006, 08:23 AM   #2
amigo-2k
Isuzu Guy
Re: Isuzu Axiom Ignition Key removal problem
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
amigo-2k is offline   Reply With Quote
Old 07-03-2006, 09:07 AM   #3
carhelper88
I had a similar problem with 1996 Isuzu Trooper, the key was stuck in the ignition for a day. I turned the steering wheel and depressed the shift lock several times while someone was trying to pull the key out. After 5 minutes of trying it worked. I had shifted the gear several times in the interim while the vehicle was turned off. I hope this helps.
carhelper88 is offline   Reply With Quote
Old 11-19-2007, 10:40 AM   #4
odaflo
I have some advise, get your $110.00 back.
odaflo is offline   Reply With Quote
Old 06-10-2013, 03:59 PM   #5
mramirez8183
what will happen if you cut the cable from the shifter to the ignition ?
mramirez8183 is offline   Reply With Quote
Bookmarks
Search this Thread:
