Go Back   Automotive Forums .com Car Chat > Buick > Park Avenue
Old 07-02-2018, 07:34 PM   #1
012620
012620's Avatar
Power steering pump
Hi, I replace power steering pump on 2000 Buick Park Avenue. Refilled reservoir to level. Used block to block system with car front raise and engine not running. A lot of air bubbles came out. Air bubbles stopped. Car steers just fine if I’m moving slow or faster. At a dead stop the car is very hard to turn steering wheel. Any suggestions.
Thanks for any ideas.
Buick Park Avenue (Base). I'm still crazy after all of my 75 years. :0)
012620 is offline   Reply With Quote
Old 07-03-2018, 06:46 AM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Re: Power steering pump
Depending on how the old pump failed, there may be damage to the rack. It could also be the replacement pump pressure relief is too low.
Blue Bowtie is offline   Reply With Quote
The Following User Says Thank You to Blue Bowtie For This Useful Post:
012620 (07-03-2018)
Old 07-03-2018, 09:09 AM   #3
012620
012620's Avatar
The power steering pump was replaced because of a leaking seal. The last year or so the power steering would sometimes wine when I started to turn right from starting out. I would stop the turn and start over and the wine always would stop. The wine would sometimes happen and sometimes not. It seem to wine more often lately.
So is this pump pressure relief item part of the power steering pump or a separate item?
Old 07-04-2018, 07:35 AM   #4
Tech II
Agree with Blue, you probably got a bad rebuild.....
Does this have MSVA, aka Magnasteer? If your rack at the spool valve has an electrical harness coming off it, you do....
Tech II is offline   Reply With Quote
The Following 2 Users Say Thank You to Tech II For This Useful Post:
012620 (07-04-2018)
Old 07-04-2018, 07:58 AM   #5
brcidd
brcidd's Avatar
At one time there was a TSB fix to drill out the high pressure outlet of the pump a few more thousandths-- I did that to mine and it worked wonders...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
The Following User Says Thank You to brcidd For This Useful Post:
012620 (07-04-2018)
Old 07-04-2018, 10:11 AM   #6
012620
012620's Avatar
Its the base model PA and has the Grand Touring option.
Old 07-04-2018, 10:17 AM   #7
012620
012620's Avatar
I saw this info on a Rock Auto vendor site.
HOW TO FREE A STUCK PRESSURE VALVE
1. Remove the pressure line from the power steering pump.
2. Remove the pressure fitting that the pressure line threads into.
3. Push on the valve that is located behind the pressure fitting. It will be spring
loaded, so you should feel it push back once it is moving.
4. After the valve is moving freely reinstall the pressure fitting, then the pressure line.
5. Follow bleeding instructions. Make sure ignition system is disabled when bleeding the system. If the vehicle is running the valve may get stuck again if air passes by it. If it does repeat this procedure.
If you have any questions, or need technical assistance please call Lares Corporation 1-800-334-5749.
Old 07-04-2018, 04:52 PM   #8
Tech II
Does the spool valve at the rack have an electrical connector?
Old 07-04-2018, 05:40 PM   #9
012620
012620's Avatar
Yes it has the electrical connector.
Old 07-04-2018, 06:49 PM   #10
Stealthee
Your worst nightmare
Stealthee's Avatar
Electrical connector on the rack would indicate Magnasteer. Just because it's a base model doesn't mean it wouldn't have it.
Stealthee is offline   Reply With Quote
Old 07-04-2018, 09:00 PM   #11
Tech II
Magnasteer provides the assist when the car is not moving.......as the car picks up speed, magnasteer gives less assist, so that you have a more road feel...basically so it's not loosey goosey at high speeds....
So the fact your power steering is ok when the car is moving, but not at a stop or at low speeds, you could have a magnasteer problem....check to make sure the harness from the rack is connected on the driver's side just above the center of the wheel well....
The EBCM controls this....you may need a scan tool capable of reading"C", or chassis codes...
Was this a problem before the pump was changed? If no, and the harness connector was not touched, it could still be the "new" pump.....
Old 07-04-2018, 09:36 PM   #12
012620
012620's Avatar
The PA had the Grand Touring option which has Magnasteer as part of the package.
Old 07-04-2018, 09:41 PM   #13
012620
012620's Avatar
The problem just started after this pump was installed.
