Go Back   Automotive Forums .com Car Chat > Ford > Freestar
Old 03-13-2011, 03:08 PM   #1
dyankee1995
2004 Ford Freestar Tire Reset/Tire Pressure light...
We recently purchased a 2004 Ford Freestar. After my husband rotated the tires and adjusted the tire pressure, the tire pressure trouble light came on and the message center is flashing tire reset. How do we reset these trouble messages?
I know in another make/model vehicle we own we have to pump the gas pedal 3 times to reset any trouble codes. I'm not sure if it is the same for this car.
Thanks in advance for any help.
dyankee1995 is offline   Reply With Quote
Old 03-14-2011, 06:27 PM   #2
aaamillertime
Send a message via AIM to aaamillertime
Re: 2004 Ford Freestar Tire Reset/Tire Pressure light...
Use your press button keys for your message centerh to have it do an automatic system check. It will check your fluids lights and such. When it checks tires, it will prompt you to hold the reset button to clear the tire pressure light oif o.k.. You have to hold it for about 7- 10 seconds, you will then hear a chyme and the light will go off.
aaamillertime is offline   Reply With Quote
The Following User Says Thank You to aaamillertime For This Useful Post:
dyankee1995 (03-14-2011)
Oil pressure light goes off when I'm driving downhill (Audi 80) Sloforo Engineering/Technical 4 08-26-2010 05:18 PM
94 Mercury Villager oil pressure light flickers; stays on runnergirl262 Villager 1 04-15-2010 08:46 PM
2004 Ford Freestar userpete1037 Freestar 1 10-30-2009 10:51 PM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
2004 ford freestar corey2225 Freestar 2 02-18-2009 10:31 PM
