Go Back   Automotive Forums .com Car Chat > Eagle > General Discussion
Old 11-21-2005, 11:23 AM   #1
fandmout
98 talon clutch master cylinder bad?
My 98-eagle talon has a clutch engagement problem. This happened without warning. The clutch is not engaging at all. I did get it home by forcing it into gear and it did not slip after it was in gear. It looks as though the slave cylinder is pushing, but I don’t know if it is pushing far enough. The master cylinder has plenty of fluid and hasn’t been leaking. The fluid is dark. Could this be clutch or master cylinders?
fandmout is offline   Reply With Quote
Old 12-05-2005, 10:14 PM   #2
theFREAKnasty82
theFREAKnasty82's Avatar
Re: 98 talon clutch master cylinder bad?
does it feel like it has air in the system where the clutch goes down w/o any resistance? If your fluid is dark, you could have something that is clogging it up, so I'd flush that out and see how that goes.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
theFREAKnasty82 is offline   Reply With Quote
Old 01-02-2006, 01:18 AM   #3
oljeeptek
I'd say you have air, or a master cyl. most likely guess.
Remember...
Old Jeeps never die, they just sometimes look that way!
oljeeptek is offline   Reply With Quote
