Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-04-2017, 10:19 AM   #1
ofert
98 Ram 1500 Transmission problems
Trans was operating perfect. Started up no movement forward or reverse. Put lever in forward or reverse and you hear a loud winning sound like splines are wiped off of a shaft. put in park sound is gone. Pan is clean no metal at all. When you start up and put in gear can feel slight applying of clutches. Any ideas?
ofert is offline   Reply With Quote
Old 08-08-2017, 09:01 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: 98 Ram 1500 Transmission problems
I used to have to put my '92 in neutral until the oil pressure built up then it would go in gear and drive normal.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
