Go Back   Automotive Forums .com Car Chat > Toyota > Pick-Up
Old 11-16-2012, 11:58 AM   #1
RickTnKC
Send a message via MSN to RickTnKC
Thumbs down 83 Toyota PU
I have 83 Toyota PU with 22R ... I hit a bump and it died, my question is , is there an inertia switch on this yr ? Where is it located? It has mechanical fuel pump no fuel engine runs if primed... don't want to replace pump and that not be problem
RickTnKC is offline   Reply With Quote
Old 12-30-2012, 11:45 PM   #2
fourwd1
AF -Advisor
fourwd1's Avatar
Re: 83 Toyota PU
I'm guessing you've solved your problem by now, but no, the 22R doesn't have that.
It's very likely your 30 yr old fuel pump has expired.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
fourwd1 is offline   Reply With Quote
Tags
fuel , pump , toyota
