| Latest | 0 Rplys |
01-29-2009, 09:58 PM | #1 | |
2003 Envoy - new battery, no fire
Just installed a new battery in my 2003 Envoy and I turn the ignition on and nothing happens (no clicking, lights do not go dim, doesn't attempt to turn over, etc.). It acts like it is in gear but I made sure that it was in park. Ran fine yesterday. Any help would be much appreciated!!
Thanks, Brad |
01-29-2009, 11:58 PM | #2 | |
Re: 2003 Envoy - new battery, no fire
All the accessories are working, but the vehicle will not crank, correct ?
The connections are nice and clean ? Did anything accidently arc ? Test for battery voltage at the yellow wire comming from the ignition switch. Check for battery voltage at the large red wire on the starter. Can you attach a test light to the starter solenoid wire, small purple wire, on the starter and see if it lights when the key is turned to the start position. Test for battery voltage on the yellow wire comming out of the gear selection, neutral/park, switch. This wire energizes the coil in the starter relay. In the "Underhood " fuse box check fuses 17 ( 10 amp), 22 ( 10 amp), & 34 ( 40amp). Hope this helps |
01-30-2009, 08:04 AM | #3 | |
Correct, all accessories are working but the vehicle will not crank. The connections seem clean and I did not notice if something arced. I will check your other suggestions tonight. Thanks for your help!
01-30-2009, 08:14 AM | #4 | |
Any aftermarket alarms, starter cut-outs, etc installed-- these sometimes need to be reset after battery replacement-- If you haven't owned the truck since it was new- you may not even know you have an alarm- some dealers install them on every new vehicle on their lots.....saves them on insurance on their inventory.....
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
