Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Old 04-22-2016, 08:25 AM   #1
n3xtgen
Question Should I get a wheel alignment ?
I recently just started to notice that my car is slightly pulling to the left. It's not much. If i let go it will go straight for a few meters before pulling. Not sure if its worth getting it realigned ?
It's an AWD car as well and I checked the tire pressure and make sure the breaks were not sticking.
Thanks
n3xtgen is offline   Reply With Quote
Old 04-22-2016, 03:55 PM   #2
maxwedge
A990 racer
Re: Should I get a wheel alignment ?
Switch to front tires Lt to rt, see what happens.
maxwedge is offline   Reply With Quote
Old 04-29-2016, 07:21 AM   #3
harleyguy
Originally Posted by SachiNayar View Post
Yes you have to do wheel alignment of your car because it helps your tires last longer also for you own life safety purpose it's well and good. One more important thing is you have to checked alignment of your car every 6,000 miles.
That's crazy you need to take it easy on the curbs. I have never heard checking alignment every 6000 miles. If everything is tight it will not change near that fast.
As for the op you said realigned have you had I'd done before? I would do like max said rotate front tires side to side. If it started all of a sudden it's more likely slipped belt in a tire.
harleyguy is offline   Reply With Quote
Old 05-12-2016, 01:18 PM   #4
Dave B.
Dave B.'s Avatar
Some time ago, I was a service manager for a major tire company. We sold 'alignment packages' that included tire rotations, air pressure checks and brake/suspension safety checks. The check interval was 5,000 miles, which worked out to about twice a year for most of our customers. If you drive only on nice, smooth roads your alignments should last much longer. But for most of us, pot-holes are a part of life. If your car is older, add in the fact that a failed ball-joint, tie rod end, or strut bushing can ruin a set of tires in short order. Those alignment packages really saved our customers a lot of money!
One other thing - in most all-wheel-drive cars, the rear wheel alignment can cause a pull just like the front wheels. When you have your alignment done, make sure that it's a 4-wheel alignment!
Best regards,
Dave B.
Dave B. is offline   Reply With Quote
The Following User Says Thank You to Dave B. For This Useful Post:
maxwedge (01-11-2017)
Old 05-12-2016, 06:10 PM   #5
maxwedge
A990 racer
Yeah and get a before and after printout.
Old 01-11-2017, 05:43 AM   #6
stephaniereinhardt
stephaniereinhardt's Avatar
It is most necessary to do wheel alignment when you found some mistakes in car wheels. Wheel alignment is the option which you can choose if you found that your car tires not rotate properly and car is pulling unnecessarily.
Signature removed by moderator
stephaniereinhardt is offline   Reply With Quote
Old 01-11-2017, 11:55 AM   #7
maxwedge
A990 racer
What are mistakes in car wheels?
