| Latest | 0 Rplys |
07-10-2009, 09:49 AM | #16 | |
Re: 1988 beretta 2.8L
MrAnon, good timing! I was hoping to update in the next day or two.
Fuel pressure is to spec's at the injector rail. Spark on all cylinders is good when cranking immediately after stall. The check engine light came on at stall but then it and the cooling fan would cycle on and off with the key on but not cranking. No codes were captured until a Code 14 after changing the Coolant Temp. Sensor as posted above. Finally bit the bullet and changed the ECM. So far, with limited testing, the vehicle has run up to 20 minutes without stalling and can be turned off and restarted at any point during that time. The cooling fan has yet to kick in. From what I have read the temperature has to be pretty high to trigger the fan so, for now, problem fixed. |
09-15-2009, 10:35 PM | #17 | |
Glad you got it fixed, how's she doing right now?...
Removed by Moderator |
10-13-2009, 11:19 AM | #18 | |
loosenut74, replaced the ECM with a rebuilt one in July and 3 months later everything is still running great. Thanks to all for the suggestions!
Hope timhunt24 got up and running. |
12-15-2009, 12:35 AM | #19 | |
glad to hear she still doing good !
Removed by Moderator Last edited by '97ventureowner; 12-15-2009 at 08:26 AM. |
02-05-2012, 07:41 AM | #20 | |
I have a 1988 chevrolet beretta that i will be parting out
Its the automatic tranny withthe 2.8 in New yORK iM PRICING IT AT 350 LOWER THAN THE PRICEOF SCRAP OR EMAIL ME FOR PARTS FROM IT FOR A LOT LESS AT unbelievableny@aol.com |
