| Latest | 0 Rplys |
05-15-2008, 03:30 AM | #46 | ||
Re: 95 Trans Sport 3.8 Rear Head Removal?
Well he took a look and a listen to it, and said the piston was possibly bent. In regards to the rod knock, wouldnt it be able to sustain its knock without the engine overheating? Thanks! |
05-15-2008, 07:50 AM | #47 | |
well if the engine is starting to spin a rod bearing and is binding up this can cause the engine to overheat... and the knock may get worse as the engine heats up and the oil thins out a bit... It sounds a lot like you spun a rod bearing... It does happen.. Been there myself
05-15-2008, 01:56 PM | #48 | ||
05-15-2008, 02:14 PM | #49 | ||
My 95 Bonneville which has the Series II 3800 Ate up a #4 Rod bearing.. As I was driving back home to WV from Florida... I was on the WV Turnpike not far from where it turns back into I-77 and then catches SR 2 North just before Ohio... I started to notice the engine Bucking more like it was binding up, and with each time it would bind the oil pressure changed... I popped it in neutral and gave it a quick rev and hear the ever so faint sound of a Rod bearing starting to( when you work on them enough, you know the sound ).... I drove another 20 Miles and then pulled into a parking lot, left the engine idling, got under the hood and gave some small revs to see how bad it was... It was not horrible bad yet and I still have 45 Psi steady oil pressure once above idle... I knew I could get a little more out of the motor being that it wasn't struggling and or overheating at all... I got back in it and drove another 70 Miles to my Home town, for most of that trip I was running about 60 In Overdrive turning the motor about 1400-1500 rpms with he AC Off... But the time I got to my Aunts front door it was a full blown knock... But the car got me there... That was Motor #2 and was low mileage, it spun #4 for no reason... Just happened... I could have replaced the motor on my own, but being that I was 1000 miles from home I didn't have all of the proper equipment to deal with it.. That turned into an $1700 Stay with the family...LOL Even funnier is that I started that car and drove it 25 more miles to the dealership that replaced the engine for me.. They dissected the engine and told me they don't see many 3800's that do that... I was really ready to get rid of the car, but didn't want car payments.... So I opted to spend the $$$$ on a replacement motor.. As for your van... Hard to tell you what to do on that... The L27 engine that you have is a dime a dozen... They are all over... But you will risk getting a not so good one... And even then replacement will be a PITA... I'd would be in the same ship as you.... Not sure if I'd junk it or fix it.. Wish i could provide more insight.. |
