| Latest | 0 Rplys |
05-16-2012, 09:19 AM | #1 | |
'03 2500 w/ 10.5 AAM Axle ?
Hey all working on an 03 2500 gas-burner P/U with the 10.5 AAM rear axle. My concern is this: I received the vehicle with a rear end noise on decelleration. After examining the contact pattern it was obvious the rear had been recently rebuilt and looked to have excessive backlash between the ring & pinion. After ordering a new gear set from chrysler, im getting the same contact pattern as before (Pinion depth correct, backlash excessive). However, no amount of adjustments made will give me the contact pattern im looking for. Set it up like chrysler wants it and its smooth and quiet on accel, but VERY noisy on decel. I've checked, double-checked & rechecked my work to no avail. I have plenty of experience rebuilding and setting up rear ends but this baffles me. Any thoughts or insight would be well received and greatly appreciated. Thanks
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
05-16-2012, 06:49 PM | #2 | |
AF - Advisor
Re: '03 2500 w/ 10.5 AAM Axle ?
Do you shim & set the pinion depth like the Dana 60's?
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
