Old 09-30-2002, 08:41 PM   #1
Frostbyte
Send a message via ICQ to Frostbyte
Clutch Masters Stage 3
I am going to be getting a new Clutch Masters Stage 3 Clutch and I was wondering if anyone has had any problems with this clutch? Also what kind of Flywheel do you guys recommend? I am looking to get a Chromoly one.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Frostbyte is offline   Reply With Quote
Old 10-11-2002, 07:19 PM   #2
TRDcavalier__O
Banned
civic ex?
Tell me u have an engine swap.
TRDcavalier__O is offline   Reply With Quote
Old 10-14-2002, 02:25 AM   #3
Self
Self's Avatar
Send a message via AIM to Self
Why do you need the clutch?? If you aren't making a significant amount over power(a lot more than stock) it's a waste of money, won't be very fun to drive on the street in traffic, and will need to be replaced sooner than a replacement OEM clutch will. Think hard about it before you do this.
There's no replacement for displacement...No, not even a turbo.
Self is offline   Reply With Quote
Old 10-14-2002, 06:57 AM   #4
civickiller
Send a message via AIM to civickiller
get a cm stage 2, and a chromoly flywheel. dont get an aluminun one
civickiller is offline   Reply With Quote
Old 10-14-2002, 01:03 PM   #5
TrailerParkJake
Send a message via Yahoo to TrailerParkJake
the cm stage 3 is just a full faced kevlar disc isnt it? I have an action clutch, full face kevlar, and it works fine, almost exact same feel as stock. although the CM PP may be different, ill have to check it out
TrailerParkJake is offline   Reply With Quote
Old 10-14-2002, 11:16 PM   #6
civickiller
the stage 2 is the full face kevlar, stage 3 is segmented
Old 10-15-2002, 11:11 AM   #7
Than3o3
i heard some race clutches last longer than OEM, at least thats what some of the ads say.
Than3o3 is offline   Reply With Quote
Old 10-15-2002, 01:55 PM   #8
Frostbyte
Well as soon as I sell my bike then I am going to be putting on a Turbonetics t04/t3 turbo. I figure why buy 2 clutches. Stage 3 is not a 6-puck. Stage 3 is still Streetable it is the Stage 4 and the stage 5 that are tought to drive on the street
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 12-01-2002, 02:06 PM   #9
Dweezil6969
i have a friend who bought a `91 civic hatch that had a stock d15 in it with an intake. the previous owner had put in a stage 4 for no good reason. it gripped well, but that was it. getting a stage 3 shouldent be that bad.
as far as the flywheel, get something that weighs is at aboun 9 pounds. if you go much lighter then getting going on the street could be difficult. to heavy and you won't notice any difference.
`91 CRX DX Kind of moves
`90 CRX Si
Can also be found on:
XceedSpeed.com, MichiganCivics.com, and Zilvia.net
Dweezil6969 is offline   Reply With Quote
Old 12-01-2002, 04:26 PM   #10
drift
drift's Avatar
Send a message via AIM to drift
i've seen a few CM pressure plates come out of transmissions with a few of the diapragm springs broken off.
drift is offline   Reply With Quote
Old 12-05-2002, 12:00 AM   #11
DGooden
Banned
YOU SHOULD BE FINE AS LONG AS YOU DONT GET A 6 PUCK CLUTCH. THEY ARE NOT GOOD FOR THE STREET AT ALL AND NOT EVEN THAT GREAT FOR DRAG RACING WITH ONLY MINOR MODS BECAUSE THERE IS NO SLIPPING ONLY ON AND OFF
DGooden is offline   Reply With Quote
Old 12-05-2002, 05:24 AM   #12
drift
drift's Avatar
HOLY SHIT!! SOMEONE KILL HIS SIG!!!
Old 12-06-2002, 09:38 AM   #13
RoBoDEATH
Send a message via AIM to RoBoDEATH Send a message via Yahoo to RoBoDEATH
and his caps lock
1998 Honda Civic EX--Si Wing--Jackson Racing Supercharger--Enkei RP07 18inch Rims--Yokohama PARADA 215/35ZR/18's--K&N Filter--Hurst ShortShifter--DC Sport Header--Greddy Cat-Back Exhaust--DC Strut Tie Bar--Eibach Springs with Ground Control Coil Overs--Ingalls Rear Camber Kit Arms--Skunk2 Front Camber Kits--Panasonic DF88 CD Player--Two 1Fared Caps--Sony Xplod 800W Amp--SPL Series II 1200W Amp--Solo Baric 15--!!!!!SOLD!!!!!!!
2001 Honda S2000 NFR--HKS Hi-Power Duel Exhaust--NRG Hood Dampers
RoBoDEATH is offline   Reply With Quote
Old 12-08-2002, 10:35 AM   #14
ric
ric's Avatar
Send a message via AIM to ric
ok heres the deal. i just put a clutchmasters stage 3 and a clutchmasters flywheel in my lude a couple days ago and anyone who tells you its unstreetable is full of shit. in fact its engagement is unbelievably smoother then the OEM clutch. im still getting used to the flywheel but that is equally as drivable. oh and my pedal pressure was increased but its still very acceptable
ric is offline   Reply With Quote
Old 12-08-2002, 11:05 AM   #15
RoBoDEATH
i read somewhere that the stage 2 clutch lasts longer than the stage 3??
Stage 2 clutch, or Stage 3 clutch? VR4Luv 3000GT/Stealth 11 03-25-2003 05:39 PM
Bookmarks
Search this Thread:
