Go Back   Automotive Forums .com Car Chat > Geo > Metro
Old 02-11-2012, 01:26 AM   #16
Moppie
Master Connector
Moppie's Avatar
Re: 93 Metro keeps burning up rear wheel bearings
Can you get to the center nut through the wheel with it mounted to the hub?
If so, forget about torquing it, get it set up, and adjust it by hand.
Tighten the hub nut until the wheel just spins freely, there should be a small amount of resistance, but no play in the wheel.
To check for play, grab it and top and bottom and give it a really strong wiggle, then dot he same side to side. Make sure the car is on good quality jack stands, or a proper lift.
Moppie is offline   Reply With Quote
Old 02-11-2012, 05:39 AM   #17
Woodie83
Woodie83's Avatar
Here we go again. If properly assembled, the tightness of that nut will not effect the bearing in any way. There is no adjustment of play in the bearing, there is no over tightening it and crushing the bearing. The torque from that nut goes through the inner race, a solid piece of metal.
Fronts are 129 lbs/ft
Rears are 74 lbs/ft
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Woodie83 is offline   Reply With Quote
Old 02-11-2012, 04:54 PM   #18
Moppie
Master Connector
Moppie's Avatar
Rears are 74 lbs/ft
In which case all the talk about torque is irrelevant, just do the damn thing up
129 lbs/ft or 74 lbs/ft isn't going to have an effect bearing life.
Old 02-29-2012, 09:57 AM   #19
Jayd3
A basic that may have been overloked is to packe the new bearings with a wheel high quality wheel bearing service rated grease, new bearing do not come with enough grease in them, and not all greases are rated for high speed high load of wheel bearings.
Jay
Jayd3 is offline   Reply With Quote
Old 02-29-2012, 09:58 AM   #20
Jayd3
Sorry for spelling I got in a hurry.
Jay
Old 04-16-2014, 08:25 PM   #21
Bazza00
Late to the party. Correct me if I'm wrong, but aren't most wheel bearings sealed now days? Kinda hard to pack them with grease.
Bazza00 is offline   Reply With Quote
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
1991 Metro Rear Wheel Bearing Issue. doug2060 Metro 5 11-22-2010 10:20 PM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:37 AM
Rear wheel bearing LAT Neon | Plymouth Neon 0 09-27-2003 04:03 PM
