Go Back   Automotive Forums .com Car Chat > Dodge > Ram Van
Old 04-03-2011, 10:29 PM   #1
1992RamVan
'92 Ram Van fuel gauge "bounce"
When I fill the van with gas the gauge goes to the full indication but after using about 1/4 of a tank (I think I have a 30 gallon tank) the gauge begins to move up and down randomly. Once I have used about 1/2 of a tank the gauge shows empty but still "bounces" a little.
How do I determine if the problem is the gauge or the sending unit?
thanks,
mike
1992RamVan is offline   Reply With Quote
Old 04-04-2011, 07:39 PM   #2
alloro
Re: '92 Ram Van fuel gauge "bounce"
I would tap into the sending unit wires with a meter and compare the readings again the dash gauge.
alloro is offline   Reply With Quote
Old 11-23-2013, 10:24 PM   #3
wizdom23
I also had the same problem with my 94 b250 conversion van. I stopped using cheaper ethanol based gas and used the non ethanol 93 octane with lucas fuel additive. the problem went away, then tried using the cheaper ethanol based gas again and the problem returned. someone told me that the ethanol gas is gumming up the fuel line. Needless to say I only use the non ethanol gas with lucas and I get much better MPG
wizdom23 is offline   Reply With Quote
2000 Sportage Fuel Gauge Not Working...HELP!! hottmpr80 Sportage 1 08-03-2010 08:35 AM
94 ram van 5.2. intermittent elec/start prob stnich Ram Van 3 07-14-2010 12:11 AM
Temperature and Fuel Gauge = Dead TESE Malibu 3 02-22-2010 06:45 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
