Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
02-02-2005, 07:08 PM | #1 | |
Re Audio Components
Are the RE Audio Re components any good? How much are they origninally now that they are on sale for 130?
02-02-2005, 08:25 PM | #2 | |
Re: Re Audio Components
Yes they're very good for the money......they're not tthe greatest things in the world though..... They're pretty bright and a little harsh, but not anything horrible.... for the money that and the CDT Ef-61 set are great.
2002 Ford Explorer Limited D31 yellow top Kenwood DDX-7017 2 Ascendant Audio Avalanche 18's 13 cuft NET ported box tuned to 27hz Autotek Mean Machine MX3000.1 Ascendant Audio Arco component set Orion 275SX (Mids) PPI Art Series A200 (tweets) Poly Mids for rear fill to come soon. |
02-02-2005, 09:29 PM | #3 | |
havent really worke with compnents yet, was wondering if i can take two 4ohm speakers(components) and apply the to a singe channel, instead of one speaker to left and one to right chanel, on a two channel amp?
02-02-2005, 09:33 PM | #4 | |
do you mean the mid and tweet on 1 channel?
or do you mean both mids and both tweets on 1 channel? if it's the former, yes, that's what the crossover is for, it splits the frequency so the lows go to the mid and the highs go to the tweet, and the amp still sees a 4ohm load on that channel if it's the latter then yes, but then you'll be sending the same signal to both your R and L speakers (or R front and R back, depending on which pair you're wiring to the single channel). Your amp will also be running at 2ohm on that channel, which should be fine for just about every 2ch amp out there.
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
02-02-2005, 09:38 PM | #5 | |
So basically i can run four speakers on a 2 channel amp right?
02-02-2005, 09:41 PM | #6 | |
you could run 25 speakers on a 2ch amp if you wanted to, as long as you watch the impedance
02-02-2005, 09:44 PM | #7 | |
Lol thnx, so juss wondering, how would u set up the wiring would it be the wiring from the crossover you would need to adjust, or like u connect both negatrive of the speakers, and bothe postivies and the put it on the crossover?
02-02-2005, 09:50 PM | #8 | |
for a single set of components on a 2ch amp, you would run wire from the +/- on one channel to the +/- on the input of the crossover, then from the +/- woofer output to the woofer, and the +/- tweeter output to the tweeter. Then the same goes for the other channel.
02-02-2005, 09:56 PM | #9 | |
Srry dont really get that, you just used on woofer and tweeter what about the other, were u connect that?
02-02-2005, 10:09 PM | #10 | |
eh?
a common crossover will look like this: there's a + and - input that comes from the amp, a + and - output that goes to the woofer, and a + and - output that goes to the tweeter
02-02-2005, 10:20 PM | #11 | |
what im trying to say is that will their be a wire connecting the twoo woofers together and the twoo tweeters together, or will two wires go from each, on to on woofer and the next to the other woofer
02-02-2005, 10:30 PM | #12 | |
well if you're putting a single set of speakers (2 mids, 2 tweets, 2 xovers) on a 2ch amp then each side (each xover/mid/tweet set) will have its own individual channel of the amp, you won't wire them to each other at all. If you're putting 2 sets of speakers (4 mids, 4 tweets, 4 xovers) on a 2ch amp then you would connect each channel on the amp to the inputs on 2 xovers, and each xover will have its own mid and tweet.
02-02-2005, 10:40 PM | #13 | |
so that would be connecting the positive of one crossover input to the positive of the other input, and then connecting one of the postives to the postive input for the amp. and the same with the negatives
02-02-2005, 10:52 PM | #14 | |
yeah, if you wanted to put 1 set of speakers (2 mids, 2 tweets, 2 xovers) on 1 amp channel. I'm guessing you want to do this so you can have the front and rear speakers all running on a 2ch amp? If so that will work, just keep in mind that you'll lose the ability to fade.
02-02-2005, 10:59 PM | #15 | |
Where the hell can I buy these? I hear so much about them and I have found nobody that sells them.. (Don;t give me a link to thier site, I know it and couldn;t find where to buy.)
