Go Back   Automotive Forums .com Car Chat > Ford > Fusion
Old 12-01-2010, 04:02 PM   #1
mt54
06 Fusion Air Bag Light
My air bag light will stay on sometimes, it seems to be more often now, sometimes if I turn off the car and restart it will go out, and sometimes not.
any ideas what I could check.
mt54 is offline   Reply With Quote
Old 12-01-2010, 04:22 PM   #2
Franco2112
Re: 06 Fusion Air Bag Light
Airbag sensor replacement by Ford. Check your dealer.
Franco
Franco2112 is offline   Reply With Quote
Old 12-01-2010, 04:33 PM   #3
mt54
is it something I could replace myself, or does it need to be done by the dealer ?
Old 12-01-2010, 10:00 PM   #4
xmech2k
There have been a lot of posts on other forums that a weak battery will cause the airbag light to come on in Fusions. Are you seeing any other signs of a weak battery? It may be worth getting the battery tested.
xmech2k is offline   Reply With Quote
Old 12-02-2010, 06:29 AM   #5
mt54
That is a good possibility, I noticed a few weeks ago my battery went dead after just a very short time I had the lights on.
I'll check it with a load tester
Thanks for the info
Mike
Old 12-21-2010, 02:25 PM   #6
mt54
FYI,, checked battery with load tester, tested weak.... replaced ,, problem solved
thanks alot for the info
Old 12-21-2010, 09:39 PM   #7
xmech2k
Glad I could help someone. Happy roads!
Old 11-12-2011, 02:56 PM   #8
fusionkurt
I too had the airbag light stay on sometimes in my '06 fusion. I read here to test the battery: The battery tested bad. New battery=no more airbag light problem.
thanks!
fusionkurt is offline   Reply With Quote
Air bag code 44, Windstar 96, 3.8l kafkacell Windstar 0 09-07-2010 07:56 AM
1996 Suburban air bag system ground 1993Suburban Suburban 1 07-05-2009 08:50 AM
96 abs & brake light, air bag light all on bobkhi Dakota 1 09-15-2006 10:37 AM
check engine light and air bag light are on! ur_06 Accent | Verna 1 01-05-2005 04:43 PM
