Go Back   Automotive Forums .com Car Chat > Ford > Contour
Old 07-10-2009, 08:30 PM   #1
clc
96 Contour GL, Blend door stuck
Stuck in defrost position, assume it is actuator which may be the white plastic object to left of glove box when glove door is dropped. Or it could be vacuum hose/motor leak, if a vacuum also controls blend door. Looking for what could be problem. Will not pull dash no matter what.
Any help greatly appreciated
clc is offline   Reply With Quote
Old 07-15-2009, 03:33 AM   #2
Davescort97
Escort guy
Re: 96 Contour GL, Blend door stuck
Lack of vacuum going to the blend door. Defrost goes on by default when the vacuum to the blend door is not there. Check hoses on intake and vacuum motor.
Davescort97 is offline   Reply With Quote
