| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
02-26-2002, 02:31 PM | #16 | |
that's not a very precise statement, is it? Aren't there plenty of fwd cars that drive just fine with no rear wing?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me... |
02-26-2002, 03:14 PM | #17 | |
If you look the car is also running a very low front splitter, which will increase the downforce on the front, and being that it is a full blown race car its probably a pretty safe asumption that its weight and weight distribution have been changed significantly from its street car form.
02-26-2002, 03:31 PM | #18 | |
A wing on a FWD car does nothing at all. Its only for the looks. A better upgrade would be to stiffen your rear springs so you have less weight transfer. It increases your acceleration and it doesn't change the look of the car.
02-26-2002, 04:21 PM | #19 | |
Thanks to everyone for the response, this is the type of information I am trying to get.
I have always been under the assumption that at high speeds, the trunk will actually raise UP due to high pressure over the trunk and low pressure under the trunk. Is this true? I do start to feel just a bit "loose" or "squirly" at high speed 80+, nothing serious but say I pass a semi at 80+ I can tell the rear will lean to one side or the other. I am not trying to get a wing so I can add it to my collection of TypeR badges and racing stickers (no i dont have any) but for pure practical application. Thanks again for all the responses. 9 |
02-26-2002, 04:31 PM | #20 | ||
or rather you meant provides a better launch... |
02-26-2002, 04:38 PM | #21 | |
There are a few more changes than just the wing.
Take a look on the camber on the front and rear wheels. The front wheel have around 0 degrees camber angle which gives the car much grip on the front wheel, and the negative camber angle on the rear which gives the car good stability when the car is turning. The negative camber also reduces grip on the rear wheels, but the wing would help to give more grip. The brakes are BIG, and a rule in braking is that both the front and the rear wheel should lock at the same time, this means if you want better braking performance also the rear wheels must have good grip. If not, the rear wheels will lock before the front, or less brake power can be used because so they will not lock. The car on the images does only have 300 hp and fwd, but can outrun a 1000 hp Toyota Supra on a track, but okey a season old used car cost around $100k-200k and is not street legal. By putting stiffer springs on the rear suspension, or by having little downforce on the rear, the grip on the cars rear end will become worse and it's not fun to be passed by the cars rear end in a turn. Stiffer springs and low downforce on a fwd dragracingcar would probably work fine, but they just go straight forward and does only accelerate, the retadation is done by a parasuit. Some cars have "wings" integrated with the body, like this fwd car http://www.whirlwind.nl/~saabcars/Ne...ery/9-5_21.htm The "wing" is placed on the trunk and is almost impossible to see, at least if you don't know it's there. Audi TT (both fwd and 4wd) was fitted with a wing just because the first produced cars had so little downfoce that the car in high speedes "flew" of the road... if you still think that a wing on a fwd is meaningless, reconsider. |
02-26-2002, 04:43 PM | #22 | ||
02-26-2002, 05:06 PM | #23 | ||
02-26-2002, 06:15 PM | #24 | ||||
Pretty much amazing
ec437 on grammar; Quote:
02-27-2002, 12:42 AM | #25 | |||||
But your generalizations on camber are just that. Under straight line acceleration and braking having the drive wheels (front wheels in this case) with near 0 camber is desired to get the largest contact patch for best performance. Under lateral loads that's not case though. The stiffest sidewall tires will still deflect somewhat under heavy loads. It depends on the weight, roll, and tire characteristics, but you generally want at least -.5 degrees (and often more) camber under heavy cornering loads. What camber you run statically on the front is a compromise of the above factors. Quote:
Its a function of the rear suspension, but they are probably cambered more because their grip matters much more while cornering then while going straight. Quote:
But I'd take you up on the Supra challenge. A drag Supra, yeah of course. But other then its surprisingly heavy, Supras can make killer track (the curvy kind) cars. |
02-27-2002, 12:46 AM | #26 | |
BTW, speaking of big brakes, take a gander of page 9 here:
http://www.baer.com/catalog/baer_color_brochure.pdf 12 piston calipers. That's just beautiful. |
02-27-2002, 05:45 AM | #27 | |||||
The brakes on the Volvo TWR S40 racing car (the car on the images I posted) is Alcon 8 piston calipers on the front with 378x28 mm discs. On the rear it's Alcon 2 pistoncalipers with 290x10 mm discs. You have right about the brakes, but a wing will help you to get more traction on the rear wheels, and you can then use better brakes on the rear. Quote:
All the things you mentioned is just so the rear discs don't lock before the front. And if you have more grip on the rear wheels you can get better brake performance just because the rear discs can brake harder without locking. The point you mentioned is around 0,3g m/s^2. Quote:
02-27-2002, 06:05 AM | #28 | |
Brake pressure regulator (105 kB)
http://217.31.167.83/~edlund/others/...eregulator.JPG |
02-27-2002, 12:36 PM | #29 | ||||
02-27-2002, 06:54 PM | #30 | |
During the acceleration grip on the rear is created without the need of a wing, but not during braking and at constant speed.
I think I even saw a fwd dragracing car with a wing... I could be wrong, the image was pretty bad. 7k was just for the calipers, don't know if that was for all four or two. The gearbox is a xtrac, don't know the exact price but it was around 50k, www.xtrac.com The engine is also mounted further back in the engine bay. The driver is also moved a bit closer to the rear, I think it's also moved a bit more to the center of the car. The drysump on the engines allow it to be placed lower in the car. And another funny thing, the adjustable pedal set cost 1500, expensive pedals. |
