| Latest | 0 Rplys |
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications. |
11-03-2004, 09:58 AM | #31 | |
Re: radar-proof body kit
Radar beam is wide enough to aim at the car. However, on a recent trip on I80/90 I found that almost all the cops were using laser (according to my radar detector). As for laser, first thing you can do is get a dark colored car, where the headlight hide (like a trans am), and get a bra for it. It will be almos immune to laser, except up close. But by than your radar/laser detector will go off.
11-03-2004, 08:42 PM | #32 | |
It radically depends on where you are as to what the police are using for speed traps... in higher-population, and more affluent areas, where the police have more money to upgrade parts, you'll find laser (or more agressive tactics!). More rural areas tend to use radar, and some really backwoods places still use K/Ka... VERY old stuff indeed, and easy to spot. Up on 90 you'll probably see newer stuff, as the tollway provides a lot of incoming cash for the various departments, including speed enforcement.
BD (Before Deer): Clean... Very Clean. AD (After Deer): Nascar Ready. Go Baby Go. |
11-15-2004, 04:29 PM | #33 | |
you can get radar resistand paint.... but its hard.
size of car and angle of surface effects radar. radar reflects off metalic parts much better than polymers. laser needs relatively flat surface... headlights number plates, large fronts on vehicles like US pickups etc. get a car with a low frontal area, pop up lights and a full plastic or c/f front... look at masking metalic parts behind the front plastic with other material... perhaps aluminium foil?? get a radar detector, get a laser jammer. paint the car black... it may not help with absorbing laser, but it might make your new low profile sports car harder to identify and make it less of a target... red is a bad colour. maybe get a car bra with some radar absorband material built in...
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history! |
11-18-2004, 10:52 PM | #34 | |
Re: Re: radar-proof body kit
Or you could get huge sheets of 1 way mirror glass and angle them so your car looks like a pyramid made of mirror. Everything would be reflected up and away from the po-po right?
P.S. keep in mind Stealth planes aren't "invisible" to radar, they are just reducing their radar return to the point that the plane looks no bigger than say a basket ball. Trying to shoot a basketball sized objet from a couple miles away, at night, while its moving at speed is considerably more difficult than getting a return from a car moving slowly, in a more or less fixed path, from 50' away. |
12-22-2004, 11:20 PM | #35 | ||
Keep the rubber side down |
01-18-2005, 03:20 AM | #36 | ||
Banned
01-18-2005, 03:23 AM | #37 | |
Banned
If You Really Want To Avoid Getting Aq Speeding Ticket Here Is A Hint.... Dont Drive Over The Limit, And If Thats A Problem For You Get A Radar Jammer. Highly Illegal So You Have To Install It Somewhere That You Would Never Think They Would Look Because When They Pull Your Ass Over For Not Showing Up On Radar They Will Get Permission Immeditly To Search Your Car...
01-18-2005, 01:20 PM | #38 | |
certain shapes also assist in providing a reduced radar signiature though. but you'd have to know what you were doing.
01-18-2005, 01:48 PM | #39 | ||
Banned
01-18-2005, 05:28 PM | #40 | ||
For your previous post, stealth jets are almost as loud as regular jets, the "stealth" part comes from the materials and shape of the jet body and frame, and the speed and altitude at which they fly. Sorry, I'm not sure that I understand the rest of the post enough to adequately refute it, but I'm sure such a correction would be required. Your sig makes no sense.
01-18-2005, 09:13 PM | #41 | ||
Re: Re: Re: radar-proof body kit
Google for Radar Cross Section to find out how radar "sees" a plane. Reducing it makes the plane's radar return signal smaller, thus making it "look" smaller. Other things, like radar absorbing materials, and venting on the tail section reduce heat returns. |
01-19-2005, 01:13 AM | #42 | |
Stealth aircraft is stealthy because of the way each plane meets the other planes on the surface of the vehicle. The shape of the aircraft has MUCH to do with its ability to go undetected by radar.
The heat is exhausted in such a way as to make it harder for heat seeking weapons to not be able to lock on to the target once it is discovered. bodykit needs a body punch
Mr. Congeniality and PROUD Infidel! |
01-19-2005, 03:09 AM | #43 | ||
01-20-2005, 07:38 AM | #44 | |
have to admit, though- wither or not the stealth technology works, those planes look seriously badass.
01-21-2005, 03:04 AM | #45 | ||
