Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 11-06-2008, 07:35 PM   #16
AF_Dali
Question Re: 97 Malibu V6 3.1L ABS Light Always On
Originally Posted by maxwedge
Keep in mind even though the sensor checks out it can still be bad. find the appropriate wires at the ebcm and check for continuity there. A scan with a abs scanner will pinpoint the suspect sensor, during a road test the wheel speed inputs can be monitored to see if one drops out or has no input.
Hi maxwedge:
I kind of found the location of the EBCM, which is located in the inner splash board of the driver's side front wheel. Should I remove the EBCM unit then measure the connectors in the box that holding the EBCM unit?
Please advise. Thank you!
AF_Dali is offline   Reply With Quote
Old 11-07-2008, 09:14 AM   #17
maxwedge
A990 racer
This can be a tough job to pinpoint the 2 wires for each wheel sensor and check continiuty in the harness back to the sensor, you must use a long jumper, of course, to each sensor wire.
maxwedge is offline   Reply With Quote
Old 11-07-2008, 10:28 AM   #18
AF_Dali
Hi maxwedge:
Glad to hear from you!
Would it be feasible to measure the resistance between two connectors at the bracket box of the EBCM Unit? If the resistance of 4 pairs of connectors to the 4 ABS sensors are close the the resistance of the sensors, then the connectivity might be ok, otherwise there is a open or short.
Please advise, thank you!
Old 11-07-2008, 02:10 PM   #19
maxwedge
A990 racer
The resistance will be higher of course, but I don't know how much over that length of harness, but if is way out of whack you know there is an issue in that circuit.
