| Latest | 0 Rplys |
10-06-2013, 06:28 PM | #16 | ||
Re: Mixing Dexcool with All color All purpose Prestone.
10-07-2013, 10:44 AM | #17 | |
from ma, no comment.
10-07-2013, 12:07 PM | #18 |
10-08-2013, 10:39 AM | #19 | |
WE don't have to register our guns, were treated like adults.
10-08-2013, 08:49 PM | #20 | |
I have a 2010 Impala 3.5L and a 2013 Impala 3.6 DOHC.
The 2010 owners manual states 'clean drinkable water' aka potable water. There is no mention of distilled water. The 2013 owners manual states 'deionized water(distilling water will deionize it as well as other methods) or clean drinkable water' So ICAT when did GM start recommending only distilled/deionized water with "Dex-Cool?" I do agree that most problems with any cooling systems or any system for that matter is neglect. |
10-09-2013, 07:37 AM | #21 | |
it is recommended that shops to have water tested for hardness,chloride,ph.if water is good then would be okay.
10-09-2013, 10:53 AM | #22 | ||
around 80,000 miles had the intake manifold gasket problem. replaced it with a"felpro" gasket. flushed with tap water several times. added prestone any kind/any color . over 120,000 miles later no problems. |
10-10-2013, 11:05 AM | #23 | |
note = the prestone i added was 100% so i diluted with 50% tap water.
10-11-2013, 12:38 PM | #24 | ||
deionized water is for batteries . when adding water to the batteries you must use this type water or you get cell plate damage ... I have the shop OEM manual and it states distilled water with the coolant. I mentioned before that I have been using distilled water with my coolant a lot longer than GM started this use ...my 1983 had no coolant problems used regular prestone silicate coolant and distilled water ..all engine gaskets no leaks/no heads/engine work etc. I did replace the water pump at 80,000miles leak at the seal. the pump I put on ran until I sold the vehicle total miles 380,000 miles.. the reason I sold it I needed 4WD to get to work ! snow storms you make the big bucks... |
10-14-2013, 11:50 AM | #25 | |
UPDATE - FYI - the short on the long is I replaced the radiator and kept the red stuff, all is well in chevmali99 3.1 world. I'll mention the following: Pep Boys or any other franchise will not change the antifreeze to non OEM recommendations for obvious reasons.
Nevertheless, mechanics say that replacing the radiator, thermostat, the water pump, along with the heater core & flushing out the system can give you the liberty to use conventional anti-freeze, because the so called OEM parts are no different than any other car. In other words, if they are not original from GM, then the red stuff is not necessary as long as you replace every other part related to the cooling / heating apparatus. If you're a DIY type with the time, money, and necessary tools let it rip! keep in mind It is a very time consuming operation not for the novice. One last thing, a while back I wrote about several cracked antifreeze reservoirs. For two years now, I've had the same reservoir with no cracking. The solution seems to have been not tightening the cap and leaving enough room for the vapor to escape through the hose. One twist of the cap, instead of a full tightening, seems to have worked. It's been a week of rigorous driving and the temp has not gone about the 3 quarter range. |
12-11-2013, 05:28 PM | #26 | |
UPDATE - I took a look at the ingredients in both Prestone All Purpose All Color All Makes & their DexCool 50/50 pre-mix... and found they differ in one ingredient that is found in DexCool & not in the other. So I decided to test Prestone's claim, not in the car but in a hot pot. I mixed a cup of the two in an old pot no one uses to cook anything (I asked my wife for permission) and heated it up. Opened a few windows because anti-freeze smell is nauseating in spite of its sweet smell. Heated it for a good 20 min and there was no obvious adverse effect, the consistency remained the same as Dexcool 50/50 or the Prestone All purpose all everything.
