| Latest | 0 Rplys |
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
11-16-2004, 04:25 PM | #76 | ||
Re: Re: Which of these subs would you get?
the aquabats are seriously the best band in the world |
11-16-2004, 04:57 PM | #77 | |
I already said that I DID notice a difference, a very large difference when I switched out the Avionixx for the Cadence, from the very first song I played after the switch. And I'm not talking about the power difference, the upper bass (60-80hz region) became much more defined, the sub sounded smoother through the whole freq range, the low bass (30-40hz region) didn't just jump in out of nowhere, it blended with itself much better than with the Avionixx. And the Avionixx was no flea-market amp, it was around $300 for 800x1. Say what you will, I know what I heard.
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
11-16-2004, 06:37 PM | #78 | |
Banned
How do you push 1350w at 2ohm and the same on the wattage on 1ohm with the same amp?.... that isnt reality. 1350@2ohm 2700@2ohm.
and all you are wrong TRU TECH ALL THE WAY. lol... too bad their stiff cost 4 times of companies such as Hifonics (whihc IMO put JBL to shame SQ wise) and no. even in Subbass power isnt power. i cna supply 900w with a clean signal or 900w from a 450w amplifier supply a nearly square (suverly clipped) wave. SQ will be horible from the 450... also, THD introduced becomes very prevelant if you know hte track once yo uget into high volumes (over 115dB is where i personally start really picking up extra harmonics) |
11-16-2004, 07:23 PM | #79 | |
boo to TRU
unless you have nothing in life to spend on except amps, go TRU. Otherwise, look for something else. lol. A buddy of mine is a dealer for TRU. While I can get TRU for cheap, I refuse to do so, mainly because I don't wanna hop on the bandwagon (ECA perhaps?) and make it like it's god's gift.
I love them sub wufers |
11-16-2004, 07:49 PM | #80 | ||
11-16-2004, 08:10 PM | #81 | ||
you a member at ECA?? CBFryman, how about you take that guy up on his challenge its 10,000 dollars in your pocket if you can tell two amps apart with the same power output, i know there might be other guidlines, but you seem to be confident that you can do it, if power isn't power....
11-16-2004, 10:36 PM | #82 | ||
Re: Re: Re: Which of these subs would you get?
Whenever TRU pops up, it's always better by default to some people i'll stick to my road gear thank you yea. i'm a member of ECA. I was many years ago, but then somehow couldn't log back in and then had to re-register and now i'm a newb again. lol
11-16-2004, 11:54 PM | #83 | ||
Re: Re: Re: Re: Which of these subs would you get?
Tru is still around and selling strong
www.cloudcity.deviantart.com |
11-17-2004, 10:06 AM | #84 | |
Tru is too damn expensive just like JL.
11-17-2004, 11:53 AM | #85 | |
tru is cheaper than jl
11-17-2004, 12:19 PM | #86 | ||
UNOFFICAL AUDIO BRAND RATINGS My life is composed of the worst luck known to man. Disclaimer: My knowledge of car audio is questionable, but it usually sounds great to me. '98 Grand Prix GT 4Dr '06 XXX 12" Possibly a Cadence ZRS-10 Pioneer DEH-5500MP |
11-17-2004, 12:20 PM | #87 | ||
11-17-2004, 03:11 PM | #88 | |
TRU's smallest T-series is obviously cheaper than the JL 1000/1. lol
11-17-2004, 03:25 PM | #89 | ||
11-17-2004, 06:42 PM | #90 | ||
Banned
as i said before (though i will shed some light on it) If i take amp 'X' rated to 1500w amp and amp 'Y' rated to 1500w. Amp 'Y' had been shown to be able to bench 1600w@1ohm clean signal. The highest reality clean wattage amp 'X' can bench is 800w@1ohm. We will look at the signal. now we all know that wattage is Amperes*voltage. @1ohm total average current passing through the coils will be 40a. this is at one ohm impeadence; in other words, what ever frequincy will give that coil exactly a 1ohm load. if at Point A amp 'X' can no longer produce a signal verticaly it must produce extra wattage horazontaly, result? clipped signal. since the voltage will stay the same for a longer period of time it will move more current in that period of time and there for more wattage. amp 'X' that can normally only produce 800w clean producing 1600w will have a suverely clipped (almost completely square) signal. this will cause the coil to slam forward, stop, idle (very short), then move in the other direction. the sound will be slightly quieter than amp 'Y' and will be very muddy and distorted (yes even bass frequincies) Amp 'Y' will make the coil move forward, stop and allow the suspension to start moving the coil back the other way untill the signal moves in the other direction. the coild stays cooler, the sound is heard as it is sappsed to be heard and is slightly louder (i say only slightly because total wattage is total wattage. the distorted wattage will be louder than the clean wattage but not as loud beause Amp 'Y' will reach greater excursions). |
Thread Tools | |
