Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-15-2013, 11:15 PM   #1
jbullet88
97 spyder 2.4 sohc accleration problem
i just got a 97 spyder eclipse 2.4l sohc. whenever i go to take off if i give it more than 10% of the gass it willl do almmost nothing. but if u just barley give it the gass it will go fine. sometimes it will not do this and run fine... messes up WAY more then it runs right. sometimes the belts just start squeeling and the lights will dime but thats not that big of a problem. everyone keeps telling me its the mass air flow. if u unplug it u it will not streaghtin up at all. usuley if u get it over 3000rpm it will go fine but sometimes that dose not work eather. i just dont understand what the problem is with it. in dier need of help b4 i spend alot of money replacing stuff thats not broke. please help
jbullet88 is offline   Reply With Quote
Old 01-16-2013, 10:28 AM   #2
SilvrEclipse
Holset powered 420a
SilvrEclipse's Avatar
Send a message via AIM to SilvrEclipse
Re: 97 spyder 2.4 sohc accleration problem
Does the car have a check engine light on? You at least need to tighten the belts if not replace it. The MAF is a good place to start checking, any leaks after it and the car will run pretty bad.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
SilvrEclipse is offline   Reply With Quote
Old 01-17-2013, 10:16 AM   #3
jbullet88
well the cars bin throwing altinator belts.. gessing a bad pully. the car sat for like 6 years in a garadge. i went to a junk yard to get a new maf sensor but they sold me the wrong one and a new one is 600$. the car just randomly starts squeeling the belts.
Old 01-17-2013, 10:17 AM   #4
jbullet88
oh yes the lights on
Old 01-19-2013, 06:33 PM   #5
SilvrEclipse
Holset powered 420a
You need to get the codes pulled on the car. Its there too tell you there is a problem so get that checked out and it will give you a direction to start looking in.
98 Eclipse GS Turbo
2001 BMW 325i - DD
