Go Back   Automotive Forums .com Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 02-09-2014, 07:46 PM   #16
Woodsm
Re: 96 Sebring hesitating and stalling intermittently
My 2002 Sebring stalls at a light or stop sign as well. I can put it in "N" and it would start but once I take it out of gear, it would stall out again and again. However, sometime it would keep running after it stalls and restarts and run if I place it in gear and press the gas quickly. Do any one knows the problem? The service nor the engine light is on.
Woodsm is offline   Reply With Quote
Old 06-01-2015, 08:50 PM   #17
royengle
If you replace the distributor cap, rotor, spark plugs, but not the sparkplug wires--that could be your problem with water.
royengle is offline   Reply With Quote
Old 06-01-2015, 08:54 PM   #18
royengle
Spark plug wires go bad with age, increasing resistance reducing spark causing misfires, poor performance, lack of power, poor fuel economy, etc.
Old 06-01-2015, 08:56 PM   #19
royengle
Originally Posted by dragonchains View Post
Has anyone found a solution to this stalling out problem with the 96 Sebring? Mine seems to drive fine until I come to a stop, then it stalls and will have to be restarted. I've replaced the throttle position sensor, idle control valve, fuel filter, and fuel pump so far. I took the car to a mechanic, and the car is only throwing one code stating the high speed fan relay is bad....to which I can't seem to find a relay for that in either of the fuse boxes (in dash and under hood).
Try replacing the MAP SENSOR.
